Chat freely about anything...
By nemik
#24238
ematson5897 wrote:For some reason it started working when I changed the uploader to DIO flash instead of QIO flash. Also have there been issues with some of them having GPIO 4 and 5 switched? Mine are flip flopped from all the pinouts on the web
The ones I have are the same way with GPIO 4 and 5 flipped, it was a real pain in the ass in the beginning.
By kolban
#24247 Howdy tytower,
What I did was download the document:
0D-ESP8266_Pin_List
which can be found here:
http://bbs.espressif.com/download/file.php?id=442
It is a spreadsheet. I then went to the tab called "Strapping" which is the bootstrapping information.
There you will find the following data:
By flagtrax
#33958 The pair I'm having issues with have exactly the same outputs as above. ...well one does, and I assume the other did, until I tried to flash it. I've tried every conceivable suggested GPIO configuration, and nodemcu flasher settings without success.
