Last change in module Digital.cpp ( INPUT_PULLUP) caused the reading of DHT22 does not work
Explore... Chat... Share...
20:31:20 **** Build of configuration Sming for project HttpServer_ConfigNetwork ****
make all
C+ app/application.cpp
C+ /opt/sming/Sming/appinit/user_main.cpp
AR out/build/app_app.a
LD out/build/app.out
/opt/sming/Sming/compiler/lib//libsming.a(HttpServer.o):(.text._ZN10HttpServer13initWebSocketER20HttpServerConnectionR11HttpRequestR12HttpResponse+0x8): undefined reference to `vtable for WebSocket'
/opt/sming/Sming/compiler/lib//libsming.a(HttpServer.o):(.text._ZN10HttpServer13initWebSocketER20HttpServerConnectionR11HttpRequestR12HttpResponse+0xc): undefined reference to `WebSocket::WebSocket(HttpServerConnection*)'
/opt/sming/Sming/compiler/lib//libsming.a(HttpServer.o):(.text._ZN10HttpServer13initWebSocketER20HttpServerConnectionR11HttpRequestR12HttpResponse+0x10): undefined reference to `WebSocket::initialize(HttpRequest&, HttpResponse&)'
/opt/sming/Sming/compiler/lib//libsming.a(HttpServer.o):(.text._ZN10HttpServer13initWebSocketER20HttpServerConnectionR11HttpRequestR12HttpResponse+0x31): undefined reference to `WebSocket::WebSocket(HttpServerConnection*)'
/opt/sming/Sming/compiler/lib//libsming.a(HttpServer.o): In function `HttpServer::initWebSocket(HttpServerConnection&, HttpRequest&, HttpResponse&)':
C:\DEV\ESP8266\Sming\Sming/Wiring/WVector.h:47: undefined reference to `WebSocket::initialize(HttpRequest&, HttpResponse&)'
/opt/sming/Sming/compiler/lib//libsming.a(CommandHandler.o):(.text._ZN14CommandHandler19procesStatusCommandE6StringP13CommandOutput+0x20): undefined reference to `system_get_rst_info'
/opt/sming/Sming/compiler/lib//libsming.a(CommandHandler.o): In function `CommandHandler::procesStatusCommand(String, CommandOutput*)':
C:\DEV\ESP8266\Sming\Sming/Services/CommandProcessing/CommandHandler.cpp:70: undefined reference to `system_get_rst_info'
/opt/sming/Sming/compiler/lib//libsming.a(RTC.o): In function `RtcClass::RtcClass()':
C:\DEV\ESP8266\Sming\Sming/SmingCore/Platform/RTC.cpp:26: undefined reference to `system_get_rst_info'
collect2: error: ld returned 1 exit status
make: *** [out/build/app.out] Error 1
20:31:21 Build Finished (took 1s.71ms)
