martinayotte wrote:If you were using 2 MOSFET circuits mentioned above tied together (only 1 pullup needed on the 3V side), you will end up with an AND configuration, so no needs for inverter ...
Martin
I still don't think you have appreciated what I am doing. My logic needs two separate NAND gates. I have the logic and the one transistor needed. I am not going to buy even one MOSFET, let alone two when I can achieve the same without. You seem to have got 'hung up' on the inverter issue. The topic, and my original query, was just about the input requirements of the ESP Rx pin. It had nothing to do with 'inverters' or level shifting. It is relevant however to anyone wanting to drive the Rx pin from any external circuitry.
Mike B
