By Torah
#27376 no. not google. Didn't you mean the WiFiClient example in arduino IDE?
* This sketch sends data via HTTP GET requests to data.sparkfun.com service.
* You need to get streamId and privateKey at data.sparkfun.com and paste them
* below. Or just customize this script to talk to other HTTP servers.
const char* ssid = "your-ssid";
const char* password = "your-password";
const char* host = "data.sparkfun.com";
const char* streamId = "....................";
const char* privateKey = "....................";
delay(10);
Serial.println(ssid);
WiFi.begin(ssid, password);
Serial.println("");
int value = 0;
delay(5000);
++value;
Serial.println(host);
WiFiClient client;
const int httpPort = 80;
return;
// We now create a URI for the request
String url = "/input/";
url += streamId;
url += "?private_key=";
url += privateKey;
url += "&value=";
url += value;
Serial.print("Requesting URL: ");
Serial.println(url);
client.print(String("GET ") + url + " HTTP/1.1\r\n" +
"Host: " + host + "\r\n" +
"Connection: close\r\n\r\n");
delay(10);
while(client.available()){
Serial.print(line);
lajolo wrote:I did not understand your reply.
Does your esp work with the google's url example?
By Torah
#27382 e.. I know it's fine. But not suitable for me. And the program on esp worked not well. So back to my question, where is the bug now in the program?
lajolo wrote:That example (sparkfun) is also ok.
Does it work for you?
By martinayotte
#27514 Is the question depends of which sites been queries, is it works for somes and not for the others ?
This mean the problem rely on the delay(10) before testing for the response, because the reponse time can vary across sites. The solution is either to wait longer or to add some timeout code such as :
Code: Select all    client.print("GET /?format=json HTTP/1.1\r\nHost: api.ipify.org\r\n\r\n");
    int timeout = millis() + 5000;
    while(client.available() == 0) {
      if (timeout - millis() < 0) {
        Serial.println(">>> Client Timeout !");
        client.stop();
        return;
    int size;
    while((size = client.available()) > 0) {
      uint8_t* msg = (uint8_t*)malloc(size);
      size = client.read(msg,size);
      Serial.write(msg,size);
      free(msg);
