2 questions?
When can I get one / how?
What sort of throughput can you have to the arduino, using i2c?
Good work!
Explore... Chat... Share...
andrew melvin wrote:Looks really interesting.
2 questions?
Good work!
danbicks wrote:Richard,
See the following post: http://www.ebay.co.uk/itm/Rev2-ESP-03-C ... 35ee530998
Very similar to your solution, already out there although this one communicates through serial without the flexibility of programming the ESP through the IDE.
Dans
