Chat freely about anything...
By Scudi
#27492 hmm I rechecked everything and seems to me looking good.
I tried to update the firmware also with no success. I used the NodeMcuUpdater and tried to update write the the INTERNAL://NODEMCU (and several others) but it always breaks with
Code: Select allNote:Serial port connected.
Note:Begin find ESP8266.
Note:ESP8266 ACK success.
Note:Set base address success.
Note:Program flash success.
Error:Write flash timeout.
interesting thing is, that the timeout is always nearly at the same time for a special firmware (version).
So for example for the AI-v0.9.5.0 AT Firmware.bin it looks like this:
I am really getting confused at this point.
As I read somewhre it might me a power problem, I even changed the power again. Now it is powerd by a 12V 2A -> 5v Voltage Regulator -> 3.3 Voltage regulator. So there should be more than enough power available.
By Scudi
#29381 I just wanted to make a short update.
I got some luck with my "flying wiring" to get one (on which I hadn't yet tried to put something on) to run in the AT command mode and could connect to a wifi etc.
Finally I got it now to the point that I am able to upload Arduino sketches, BUT only when using the Staging, not the Stable, version. And still I cannot upload using nodemcu or something else.
So currently I am kind of happy, that at least something works. But I am also still confused and also a bit frustraded, that I am not able to upload something different than a sketch.
By flagtrax
#29454 Just to make sure, you didn't mention whether you had the reset pulled high. I've seen weird things leaving it float. Also make sure all your components have a common ground. IE: FTDI, UNO, (what ever you are communicating through.
