I've got pl-based usb-uart convertor (tx rt gnd) and esp 12 and 12e controllers linked to 800mA power supply. I flashed it to nodeMCU and from Arduino ide, tried with pull up resistors and with direct connections as described in docs, different power supplies - it all works fine while it's comnnected to usb, but dose not start at all if usb is disconnected. The only thing i do against the documentation is that i keep gpio0 on the ground during flashing, while it's supposed to be disconnected just after start-up as i understand. Any advice on what can be done with it?
Thanks a lot!
