- Wed Dec 07, 2016 9:32 am
#59214
I have a cloned Wemos D1 mini board. That works great and stable for weeks.
However if I use a simple timer interrupt that each second updates an integer, it becomes unstable and resets within 10 minutes.
It is powered by an usb-cable from my display. (The Wemos D1 mini has a built-in serial converter and voltage regulator.)
If the problem is in my software, please explain why and how to work around? Still using the interrupt please!
I cannot imagine, yet, that this has something to do with the power supply.
If the problem is in my hardware what hardware is proven flawless?
void timer0_ISR (void)
timer0_write(ESP.getCycleCount() + 80000000L); // 80MHz ~ 1sec
ticks++;
Exception (0):
epc1=0x40201c24 epc2=0x00000000 epc3=0x00000000 excvaddr=0x00000000 depc=0x00000000
ctx: sys
sp: 3ffffc50 end: 3fffffb0 offset: 01a0
>>>stack>>>
3ffffdf0: 00000006 00000006 42d80000 42d80000
3ffffe00: 402218aa 3ffefcf4 3fffc248 4000050c
3ffffe10: 40004384 00000030 00000016 ffffffff
3ffffe20: 60000200 00000002 74007004 80000000
3ffffe30: 20000000 3fff05e8 80000000 203fc160
3ffffe40: 00000000 3fffc6fc 3ffe91f4 3fff05ec
3ffffe50: 00000194 003fc160 60000600 00000030
3ffffe60: 7fffffff 3ffe9c7c 3ffe9c7c 00000001
3ffffe70: 402222e1 3ffe8da0 00000000 00000000
3ffffe80: 40101180 0af4bda3 3ffefd0c 00000000
3ffffe90: 00000000 00000000 0000001f 4010103d
3ffffea0: 4000050c 0ad8216b 4022697b 3ffefd0c
3ffffeb0: 40000f68 00000030 00000011 ffffffff
3ffffec0: 40000f58 00000000 00000020 00000000
3ffffed0: 00000007 4021accc 3ffe91f4 bfffffff
3ffffee0: ffffffff 3ffefd0c 3ffe91f4 3fffdab0
3ffffef0: 00000000 3fffdcb0 3ffe8918 00000030
3fffff00: 00000000 400042db 00000064 60000600
3fffff10: 40004b31 3fff0484 000002f4 003fc000
3fffff20: 40101f6e 3ffe8900 3ffe90a0 40106fec
3fffff30: 4021a79d 3ffe90a0 3ffe8900 23bc956a
3fffff40: 3fff0484 00001000 4021ac32 00000008
3fffff50: 4021cbb4 3ffe91f4 4021acdf 3ffe9154
3fffff60: 3ffe8900 0ad89471 3ffe8900 60000600
3fffff70: 40203249 3ffe9154 3ffe8900 23bc78c6
3fffff80: 4020328e 3fffdab0 00000000 3fffdcb0
3fffff90: 3ffe8920 00000000 40000f65 3fffdab0
3fffffa0: 40000f49 000181d6 3fffdab0 40000f49
<<<stack<<<
ets Jan 8 2013,rst cause:2, boot mode:(1,6)
ets Jan 8 2013,rst cause:4, boot mode:(1,6)
wdt reset
