- Tue Sep 08, 2015 9:31 pm
#28664
I replaced 3 files in my environment, built, and get the following errors:
ESP8266WebServer.cpp
ESP8266WebServer.h
WiFiClient.cpp
Maybe you have a newer WiFiClient.h?
Arduino: 1.6.5 (Windows 7), Board: "Generic ESP8266 Module, Serial, 80 MHz, 40MHz, DIO, 115200, 512K (64K SPIFFS)"
C:\Users\Greg\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\1.6.5-947-g39819f0\libraries\ESP8266WiFi\src\WiFiClient.cpp:180:50: error: no 'size_t WiFiClient::write_P(const char*, size_t)' member function declared in class 'WiFiClient'
size_t WiFiClient::write_P(PGM_P buf, size_t size)
C:\Users\Greg\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\1.6.5-947-g39819f0\libraries\ESP8266WiFi\src\WiFiClient.cpp:293:31: error: no 'IPAddress WiFiClient::localIP()' member function declared in class 'WiFiClient'
C:\Users\Greg\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\1.6.5-947-g39819f0\libraries\ESP8266WiFi\src\WiFiClient.cpp:301:32: error: no 'uint16_t WiFiClient::localPort()' member function declared in class 'WiFiClient'
C:\Users\Greg\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\1.6.5-947-g39819f0\libraries\ESP8266WiFi\src\WiFiClient.cpp:332:48: error: no 'void WiFiClient::stopAllExcept(WiFiClient*)' member function declared in class 'WiFiClient'
void WiFiClient::stopAllExcept(WiFiClient * exC) {
Error compiling.
