By somkoder
#28710 Ok so I just published the sources for the initial version of a mini "router" I wrote. I am getting about 10mbps throughput with it.
Code: Select allMinimalistic Wifi Packet Forwarder using ESP8266 Wifi Transceiver v1.0
This is not a traditional router. This is a packet forwarder with a simple binary protocol to send and receive packets between connected devices using the ESP8266 as intermediary.
It can handle up to 254 connected devices, although the limit is currently set to only 5 in the code ahead. You can change that limit easily just by setting the amount on the MAX_SLOTS define.
The protocol is as follows:
On first sent packet, a device will identify itself with a single-byte packet to the Forwarder telling which device index it is going to use. Each connected device must have a unique index from 1-254 (index 0 = the Forwarder itself).
If a device wants to have its index automatically assigned, it should then specify its index as 255 on the first packet.
The Forwarder will always answer the first packet with a new single-byte packet back to the device containing its assigned index, or a single-byte packet with 255 if no index was assigned (index collision or not available slots).
After having been identified on the network, a device can start sending and receiving packets.
To send packets to another device, a device sends then a packet with the following format:
[SRC][TGT][PKT]
[SRC]: 1 byte - tells which device is contacting the Forwarder. [TGT]: 1 byte - target device to receive the packet. [PKT]: variable width - the packet itself.
The Forwarder will then send the very same packet (including the two header bytes) to the target device identified by that TGT index.
There is also a simple LED feedback to know when it's in AP (slow blinking) and Station mode (faster blinking). When it receives packets, the LED also is kept on for a few seconds.
Also, this initial version routes only UDP packets, but it's very easy to switch to TCP, and in the near future I may add switches for these things. If you have critics and suggestions, please post here or on the repository.
It can handle and forward packets between up to 254 connected devices, although the limit is hardcoded to only 5 devices at this moment. You can of course change the limit just by editing that amount in the code. As said above, in my tests I'm getting about 10mbps throughput with this forwarder.
Source-Code for the ESPForwarder:
https://github.com/imerso/ESPForwarder
It uses my ESPWebConfig library which is also open here:
https://github.com/imerso/ESPWebConfig
Just install the ESPWebConfig library to your arduino libraries folder to be able to compile ESPForwarder.
