Chat freely about anything...
By mknweb
#28828 So I finally got myself a ESPS8266, super stoked to build numerous projects with it!
I bought mine on Ebay, no where states what firmware it is, I'm assuming it's default.
When I boot it there's no blue blink at all, I'm able to connect via serial and send commands. Blue led blinks on Rx, however I do not get any response back to serial monitor (in this case using arduino IDE, but using anything got no response).
First thing I did was connect the usbuart ux=>rx via the ESP: Serial monitor shows that commands are definitely being sent.
Any idea on potential issue?
By mknweb
#28838 So I actually realized that CH_PD needs to be connected to 3.3v.. At first it didn't make sense because was getting pretty warm, so I kept disconnecting it. At one point keeping it connected and running a serial test returned the garble I was looking for at 115 baud rate (it's really stupid that all the sellers have this value all over the place).
Sad part now is the usb-uart stopped working completely, regardless of driver reinstallation.
By ridge
#28839 I have noticed many guys getting started have problems with using esp parts on breadboards.
For me, it is worth the extra cost for an engineered product.
If I ever want to spin a circuit board for a project it is helpful to have a known good example for copying the power and pull-ups.
I have had good luck with these from a US vendor.
http://www.ebay.com/itm/ESP8266-ESP-12-WIFI-Eval-Brd-w-2A-Battery-Holder-Free-Shipping-Arr-1-10-Biz-Days-/281585428919?hash=item418fcca9b7
For other countries, the AliExpress price is very good for the same item. (Better actually, I just noticed they went from a 12 to 12E. More exposed pins!)
http://www.aliexpress.com/item/ESP8266-ESP-12E-serial-WIFI-Industrial-stable-version-A-full-test-board-Full-IO-leads/32370570377.html?spm=2114.01020208.3.2.A4MUd1&ws_ab_test=201407_3,201444_6,201409_5
These are so generic, they don't even have a manufacturer logo or revision on the pcb silkscreen. :D
The bent connector pin on the one from aliexpress is either horrifying or hilarious. :shock: The price is low... quality is :roll:
By AJB2K3
#28866
ridge wrote:I have noticed many guys getting started have problems with using esp parts on breadboards.
My problem was that the jumper wires didn't contact with the arduino's tx/rx pins.
Once I fixed that everything was working.
