When looking at 74800 connection speed I can see boot, but there is no ready message and I cannot access the board using ESPLORER or LUA UPLOADER. ESPLORER says it has connected but cannot detect firmware version. After trying flashing using different versions of nodemcu firmware I have uploaded sketch using Arduino IDE and it works fine.
Thinking, it might be related to a specific item, I have ordered another ESP-01 module, from different seller and the situation is exactly the same - I can run any sketch from Arduino IDE and it works, but when loading nodemcu, the upload is succesful, but after reboot or reset I cannot access the firmware and I am getting garbage and MEM CHECK FAILED message and ESPLORER is not able to perform any operation on the board.
Do you have any idea, what might be wrong or why nodemcu firmware does not work as expected, whereas Arduino IDE and AT firmware is working fine?
