I've got 3 pieces esp-01 modules. One of them is dead, another is dying in the same way as first have died. What does it mean?
First symptom is that module sometimes sends garbage on its serial port, but after a sw reset it is ok. Appearing garbage gets more often as module is used. At one point module sends only garbage and it cannot be healed further. The complete process takes 1-2 days with continous usage.
One may think this is because I'm using it at 5V. But not, I power the module from 3.3V definitely and I use a voltage divider for ESP's RX pin (it is connected to an 5V arduino). I've double-treble checked it.
Do you have any idea what can be wrong?
Thanks,
D
