Chat freely about anything...
By BlitzSSS
#31582 Hi All
I'm using an ESP-07/12 with one of those white adapter plates which has the built in 10k pull up resistor for CH_PD to enable the chip.
If I want to disable the chip can I simply use a stronger pulldown resistor? If so can anyone please suggest a resistor and is this safe to do so for periods of around 1 minute or just really bad practice?
For a bit more info, I'm using the ESP as a WiFi module with an Arduino issuing AT commands. I want to be able to put the ESP to sleep between these commands so I figure I have 2 choices:
1) disable the chip by pulling down CH_PD with an Arduino's GPIO.
2) put the ESP to sleep using AT+GSLP and then trigger the reset pin via the Arduino when I want to wake it up (should I use a pulldown resistor for this?)
Obviously I could remove the pullup resistor from the plate or not use the plate at all for this scenario but I thought I'd ask anyways.
Thanks
By dkinzer
#31596
BlitzSSS wrote:If I want to disable the chip can I simply use a stronger pulldown resistor?
You don't need to add a pulldown (and, in fact, depending on the value that may not even work due to the voltage divider effect). All you need to do is to ground CH_PD (either directly or by applying a logic 0 signal). You can maintain that state for as long as you would like and no damage will ensue. After all, a 10K resistor from 3V3 to ground only conducts 0.33 mA (V divided by R) and only dissipates slightly more than a milliwatt (V squared divided by R).
If the situation involved a pullup rather than a pulldown you would simply connect to Vcc or apply a logic 1 signal. The same current and power considerations apply.
The preceding discussion applies to pins that are inputs as CH_PD is. Pins that are outputs have different considerations.
