martinayotte wrote:Password length needs to be between 8-63 characters.
viewtopic.php?f=8&t=4150&p=25193&hilit=password+characters#p25176
thank you!
you are right , but we should also need to change the cfg.mode as AUTH_WPA2_PSK too.
Explore... Chat... Share...
