I've successfully flashed an ESP07 with nodemcu using the flasher associated. Now I try to flash an ESP12 and have issues. I know the module tested good when I received it , testing with AT commands. I also have read about additional GPIO conditioning on the ESP12 . What is happening is that the flasher receives the mac address, flashing starts runs for about 10 seconds or so and stops. Checking the log shows around 20+ successful writes, then a time out error. I've seen this issue discussed all over the internet, with no real answer offered. I won't bore you with minutia, power is good, wiring verified, ports are working, again flashing starts then...........timeout. Any help appreciated.
