You need to refer the "D?" (see your posted picture) in the lua for the corresponding GPIO.
Eg. so PIN 4 -> GPIO 2
-Venkatesh
Explore... Chat... Share...
Moderator: Mmiscool
According to IGRR ...
igrr commented on Jul 22
NodeMCU has weird pin mapping.
Pin numbers written on the board itself do not correspond to ESP8266 GPIO pin numbers. We have constants defined to make using this board easier:
static const uint8_t D0 = 16;
static const uint8_t D1 = 5;
static const uint8_t D2 = 4;
static const uint8_t D3 = 0;
static const uint8_t D4 = 2;
static const uint8_t D5 = 14;
static const uint8_t D6 = 12;
static const uint8_t D7 = 13;
static const uint8_t D8 = 15;
static const uint8_t D9 = 3;
static const uint8_t D10 = 1;
These are defined here.
If you want to use NodeMCU pin 5, use D5 for pin number, and it will be translated to 'real' GPIO pin 14.
