By craiglindley
#33880 Hello,
I've been playing around with the WiFiScan example program using both the stable and the staging releases of the code. I'm using a brand new NodeMcu Amica from electrodragon. In my house there is only a single WiFi network.
The code compiles and runs but it only loops about 5 times before crashing. Here is a typical run:
l 0
chksum 0x42
csum 0x42
scan done
1 networks found
1: CraigNet (-53)*
scan start
scan done
1 networks found
1: CraigNet (-58)*
scan start
scan done
1 networks found
1: CraigNet (-57)*
scan start
scan done
1 networks found
1: CraigNet (-56)*
scan start
scan done
1 networks found
1: CraigNet (-56)*
scan start
ets Jan 8 2013,rst cause:4, boot mode:(1,0)
wdt reset
It obviously crashing in the WiFi.scanNetworks() function call.
Anyone else seen this? Anyone have a solution?
By RogerClark
#34124 I'm getting the same thing.
I don't know if this is occurring because I'm already connected to a network.
I'm using the latest version of the repo as I need SPIFFS, so this could partially be the issue as well.
Edit
I found the problem
Nothing to do with scanning. It was just that the compiler is not checking the return types and I had not returned the expected data type in one of the return; statements
