Chat freely about anything...
By dexterkhm
#3403 Hello everyone. I have two boards esp8266 like this https://mcuoneclipse.files.wordpress.com/2014/10/esp8266-pinout1.png and i have a problem with them. I connected RX a TX to lines FTDI chip , Reset and CH_PD pulled to 3.3v and I am using LM317 as USB 5V to 3.3V converter. So I started terminal session and here the results.
Code: Select allAT
AT
OK
AT+CWMODE=1
AT+CWMODE=1
OK
AT+CWLAP
AT+CWLAP
ERROR
AT+CWLAP
AT+CWLAP
ERROR
AT+CWLAP
AT+CWLAP
AT+CWLAP
+CWLAP:(4,"galinka",-89,"ec:23:3d:b5:96:d4",1)
+CWLAP:(2,"LG",-34,"5a:a2:b5:f3:38:02",1)
+CWLAP:(4,"YUNASKO",-83,"f8:d1:11:2b:dd:7c",1)
+CWLAP:(3,"Hotels3d.com",-64,"d8:50:eAT+CWLAP
6:f4:6f:48",11)
OK
busy p...
AT+CWJAP="LG","11111111"
FAIL
So esp8266 searching AP well but module does not want to connect to it. I tried two esp8266 and two Access Points and in both variants result is "FAILED". I even flashed v0.922 firmware in one of the module but result left the same. Can anyone give me an advise what I am doing wrong?
By dexterkhm
#3407 5 minutes ago find my mistake with CWMODE but i tested AT+CWMODE=3 and AT+CWMODE=2 but AT+CWJAP="HomeNet","*************" returning FAIL. But when i create AP by ESP8266 everything works fine and my notebook connecting to ESP8266. What a hell is wrong with AT+CWJAP=
By dexterkhm
#3408 Even when AP is open an no password, connect=FAIL :evil:
Code: Select allAT+CWMODE? +CWMODE:3
OK
AT+CWLAP
ERROR
AT+CWLAP
ERROR
AT+CWLAP
ERROR
AT+CWLAP AT+CWLAP busy p...
+CWLAP:(0,"LG",-38,"5a:a2:b5:f3:38:02",1)
+CWLAP:(2,"HomeNet",-75,"cc:b2:55:30:77:0e",6)
OK
AT+CWJAP="LG",""
FAIL
AT+CWSAP="home","11111111",1,0
OK
AT+CWLIF
OK
AT+CWLIF
192.168.4.100,00:1f:3c:62:6d:96
OK
By the way my firware version is 0018000902
By Bananis
#3450 I've seen this issue with CWJAP failing using my own FW built on SDK 0.9.3. Usually it helps if I restart the device a couple of times.
Apparently a new release of the AT code by Espressif is due today(?) so hopefully it solves a few of the bugs as well.
/Bananis
