The data (files to be loaded to Flash, webpages + pictures etc.) is stored in a "data" folder in the sketch folder.
This is one of mine........
C:\Users\VideoEditor\Documents\Arduino\WLANMonitor\ESP-07-2DHT-BMP180-LCD_FSLOG\data
http://arduino.esp8266.com/versions/1.6.5-1160-gef26c5f/doc/reference.html#uploading-files-to-file-system
Some useful interaction with LCD and SPiffs to get 40 chars on a 16 char screen for both lines.......
This is a bit ugly but the conversion of data type is demonstrated.
LiquidCrystal Library - scrollDisplayLeft() and scrollDisplayRight()
http://www.arduino.cc/en/Tutorial/LiquidCrystalScroll
// include the library code:
#include "FS.h"
#include <Wire.h>
#include <LiquidCrystal_I2C.h>
LiquidCrystal_I2C lcd(0x3F,16,2); // set the LCD address to YOUR LCD ADDRESS !!!
#include <NeoPixelBus.h>
#define pixelCount 40
NeoPixelBus strip = NeoPixelBus(pixelCount, 13);
uint16_t effectState = 0;
// WiFi connection
const char* ssid = "ssid";
const char* password = "Password";
const char* host = "EM-Pixel-LCD";
IPAddress apIP(192, 168, 6, 1);
WiFiServer server(80);
WiFiClient client;
extern "C"
#include "user_interface.h"
ADC_MODE(ADC_VCC);
#if defined(ARDUINO) && ARDUINO >= 100
#define printByte(args) write(args);
#else
#define printByte(args) print(args,BYTE);
#endif
String texttod = "This is a message from the Internet !..."; // 40 Bytes per Line....!!!
String texttod1 = "ABCDEFGHIJKLMNOPQRSTUVWXYZ0123456789:+=|";
uint8_t bell[8] = {0x4,0xe,0xe,0xe,0x1f,0x0,0x4};
uint8_t note[8] = {0x2,0x3,0x2,0xe,0x1e,0xc,0x0};
uint8_t clock[8] = {0x0,0xe,0x15,0x17,0x11,0xe,0x0};
uint8_t heart[8] = {0x0,0xa,0x1f,0x1f,0xe,0x4,0x0};
uint8_t duck[8] = {0x0,0xc,0x1d,0xf,0xf,0x6,0x0};
uint8_t check[8] = {0x0,0x1,0x3,0x16,0x1c,0x8,0x0};
uint8_t cross[8] = {0x0,0x1b,0xe,0x4,0xe,0x1b,0x0};
uint8_t retarrow[8] = { 0x1,0x1,0x5,0x9,0x1f,0x8,0x4};
////////////////////////////////////NTP
char tDigit;
String TiMeS,TMnow,MyNtP; // The current TimeStamp from Google....
int tIMeh,tIMem,tIMes,newt,newt1,inChar,SCsa,MNsa,HRsa;
boolean got_text = false; //Print the Text to LCD if true......
int hr,mn,st,st1; // Uptime Duration Counter......
String DsTable; //Discarded parts if the Strings......
String tmtxt1,tmtxt2,DisTeXt0,DisTeXt1; //Strings from the Web....
String theDate,theDate1,duration1,theDateTr; // The current TimeStamp Date from Google....
unsigned long ulMeasCount=0; // values already measured
unsigned long ulMeasDelta_ms; // distance to next meas time
unsigned long ulNextMeas_ms; // next meas time
unsigned long ulReqcount; // how often has a valid page been requested
unsigned long ulReconncount; // how often did we connect to WiFi
String emailbutton = "off";
void setup(){
strip.Begin();
strip.Show();
SetRandomSeed();
lcd.init(); // initialize the lcd
lcd.backlight();
// initialize the SPIFFS
if (!SPIFFS.begin()) {
lcd.print("SPIFFSinitFailed");
while(1);
// clear any old data....
if (!SPIFFS.format()) {
lcd.print("format failed");
while(1);
WiFi.mode(WIFI_AP_STA);
WiFi.softAPConfig(apIP, apIP, IPAddress(255, 255, 255, 0));
WiFi.softAP("DDT-Display http://192.168.6.1"); // Connect to WiFi network
lcd.clear();
lcd.print("Connecting to ");
lcd.setCursor(0, 1);
lcd.print(ssid);
WiFi.begin(ssid, password);
delay(1500);
lcd.print(".");
server.begin();
// connect to Google and get time
ulMeasDelta_ms = ( (unsigned long) 60 * 1000); // Sample Interval 60 Seconds, this can be placed above in the declarations....
ulNextMeas_ms = millis()+ulMeasDelta_ms;
WiFiClient client;
while (!!!client.connect("google.com", 80)) {
lcd.clear();
lcd.print("connection fail!");
client.print("HEAD / HTTP/1.1\r\n\r\n");
while(!!!client.available()) {
yield();
while(client.available()){
client.readStringUntil('\n');
theDate1 = client.readStringUntil('\r'); //Date: Tue, 10 Nov 2015 19:55:38 GMT
if (theDate1.startsWith("Date:")) {
TiMeS=theDate1;
theDate = theDate1.substring(6,23);
client.flush();
client.stop();
inChar = TiMeS.charAt(30);
newt=inChar-48; // Convert Numerical Char to int.....
inChar = TiMeS.charAt(29);
newt1=inChar-48;
tIMes=(newt1*10)+newt;
inChar = TiMeS.charAt(27);
newt=inChar-48;
inChar = TiMeS.charAt(26);
newt1=inChar-48;
tIMem=(newt1*10)+newt;
theDateTr = theDate1.substring(6,35);
inChar = TiMeS.charAt(24);
newt=inChar-48;
inChar = TiMeS.charAt(23);
newt1=inChar-48;
tIMeh=(newt1*10)+newt;
MyNtP=" ";
MyNtP+=theDate;
if (tIMeh<10){MyNtP+="0";}
MyNtP+=tIMeh;
MyNtP+=":";
if (tIMem<10){MyNtP+="0";}
MyNtP+=tIMem;
MyNtP+=":";
if (tIMes<10){MyNtP+="0";}
MyNtP+=tIMes;
MyNtP+=" GMT";
duration1 = " ";
st1 = millis() / 1000;
st = millis() / 1000;
mn = st / 60;
hr = st / 3600;
st = st - mn * 60;
mn = mn - hr * 60;
if (hr<10) {duration1 += ("0");}
duration1 += (hr);
duration1 += (":");
if (mn<10) {duration1 += ("0");}
duration1 += (mn);
duration1 += (":");
if (st<10) {duration1 += ("0");}
duration1 += (st);
HRsa=hr+tIMeh;
MNsa=mn+tIMem;
SCsa=st+tIMes;
if (SCsa>59){SCsa-=60;MNsa+=1;}
if (MNsa>59){MNsa-=60;HRsa+=1;}
if (HRsa>23){HRsa-=24;}
TMnow = " ";
TMnow += theDate;
if (HRsa<10){TMnow += "0";}
TMnow += HRsa;
TMnow += ":";
if (MNsa<10){TMnow += "0";}
TMnow += MNsa;
TMnow += ":";
if (SCsa<10){TMnow += "0";}
TMnow += SCsa;
// set up the LCD's Byte Memory
lcd.createChar(0, bell);
lcd.createChar(1, note);
lcd.createChar(2, clock);
lcd.createChar(3, heart);
lcd.createChar(4, duck);
lcd.createChar(5, check);
lcd.createChar(6, cross);
lcd.createChar(7, retarrow);
lcd.clear();
DisTeXt0 = MyNtP;
DisTeXt1 = theDate1.substring(5,35);
neWTime();
lInE1();
// (re-)start WiFi
void WiFiStart()
ulReconncount++;
delay(1000);
lcd.clear();
lcd.print(ssid);
delay(1000);
lcd.print(".");
lcd.clear();
lcd.print("WiFi connected");
// Start the server
server.begin();
WiFiClient client;
server.begin();
lcd.print("Server started");
lcd.clear();
lcd.setCursor(0, 0);
lcd.print("Network Started ");
// Print the IP address
lcd.print("IP= ");
lcd.print(WiFi.localIP());
lcd.clear();
lcd.print("Environment | ");
lcd.print(ulReconncount);
lcd.print("Monitor ");
lcd.print(TMnow);
void wsysreset()
//Perform challenge to user before getting here to reboot !!!
//Make an attempt to send mail or other backup of log files then reboot
ESP.restart();
void lInE1(){
int ttdlgt;
lcd.clear();
// Print a message to the LCD.
lcd.print(DisTeXt0);
lcd.print(DisTeXt1);
int ttdlgt0 = DisTeXt0.length();
int ttdlgt1 = DisTeXt1.length();
if (ttdlgt0>ttdlgt1){
ttdlgt=ttdlgt0;
}else{
ttdlgt=ttdlgt1;
// scroll 16 positions + Extra text (string length - display length) to the left
for (int positionCounter = 0; positionCounter < ttdlgt-16; positionCounter++) {
// scroll one position left:
lcd.scrollDisplayLeft();
// wait a bit:
lcd.home();
void neWTime(){
duration1 = " ";
st = (millis() / 1000);
mn = st / 60;
hr = st / 3600;
st = st - mn * 60;
mn = mn - hr * 60;
duration1 += (hr);
duration1 += (":");
duration1 += (mn);
duration1 += (":");
duration1 += (st);
HRsa=hr+tIMeh;
MNsa=mn+tIMem;
SCsa=st+tIMes;
TMnow = " ";
TMnow += theDate;
TMnow += HRsa;
TMnow += ":";
TMnow += MNsa;
TMnow += ":";
TMnow += SCsa;
// create HTTP 1.1 header
String MakeHTTPHeader(unsigned long ulLength)
String sHeader;
sHeader = F("HTTP/1.1 200 OK\r\nContent-Length: ");
sHeader += ulLength;
sHeader += F("\r\nContent-Type: text/html\r\nConnection: close\r\n\r\n");
return(sHeader);
// make html footer
String MakeHTTPFooter()
String sResponse;
sResponse = F(" ");
sResponse += F("<BR>environmental.monitor.log@gmail.com<BR><FONT SIZE=-2>ESP8266 With DHT11 & BMP180 Sensors<BR><FONT SIZE=-2>Compiled Using ver. 1.6.5-1160-gef26c5f, built on Sep 30, 2015</body></html>");
return(sResponse);
neWTime();
// Check button for email trigger
int button = 0; // variable for reading the pushbutton status
button = digitalRead(0); // read the state of the pushbutton on gpio 0
if (button == LOW) {
emailbutton = "Send";
lcd.clear();
lcd.print(F("Email Button...."));
lcd.print(F("......Pressed.!!"));
delay(1000);
if (emailbutton == "Send"){
// There are three fun functions that implement different effects
// uncomment one at a time and upload to see the effect
// LoopAround(192, 200); // very interesting on rings of NeoPixels
PickRandom(128);
// FadeInFadeOutRinseRepeat(192);
// start animating
strip.StartAnimating();
// wait until no more animations are running
while (strip.IsAnimating())
strip.UpdateAnimations();
strip.Show();
delay(31); // ~30hz change cycle
// main loop
if (millis()==(ulNextMeas_ms-(ulMeasDelta_ms/2))){
if (got_text == true){
if (tmtxt1!=""){
lcd.clear();
lcd.print(tmtxt1);
if (tmtxt2==""){
DisTeXt1 = TMnow;
lcd.print(TMnow);
}else{
DisTeXt1 = tmtxt2;
lcd.print(tmtxt2);
else{ // Empty String returned CLEAR SCREEN
got_text == false;
lInE1();
lcd.clear();
lcd.print(theDateTr);
lcd.print(TMnow.substring(18,26));
// Ping or PIR and check email button Halt/Reboot
if (TMnow.startsWith("00:04") || emailbutton.startsWith("Sen")) {// Set the time for the Log to be emailed
lcd.print(F("Got email - data"));
/* if(sendEmail()) {
lcd.clear();
lcd.print(F("mail sent......"));
wsysreset();
else {
lcd.clear();
lcd.print(F("Email FAILED..!!!"));
while(1);
// do data logging
if (millis()>=ulNextMeas_ms)
if (tmtxt1!=""){
lcd.clear();
lcd.print(tmtxt1);
if (tmtxt2==""){
DisTeXt1 = TMnow;
lcd.print(TMnow);
}else{
DisTeXt1 = tmtxt2;
lcd.print(tmtxt2);
got_text == false;
lcd.clear();
if (theDate.startsWith("00:04") || emailbutton.startsWith("Sen")) {// Set the time for the Log to be emailed
lcd.clear();
wsysreset();
else {
lcd.clear();
while(1);
// check if WLAN is connected
if (WiFi.status() != WL_CONNECTED)
WiFiStart();
if (!client)
return;
// Wait until the client sends some data
unsigned long ultimeout = millis()+250;
while(!client.available() && (millis()<ultimeout) )
delay(1);
if(millis()>ultimeout)
return;
String sRequest = client.readStringUntil('\r');
client.flush();
// stop client, if request is empty
if(sRequest=="")
client.stop();
return;
// get path; end of path is either space or ?
// Syntax is e.g. GET /?show=1234 HTTP/1.1
String sPath="",sParam="", sCmd="";
String sGetstart="GET ";
int iStart,iEndSpace,iEndQuest;
iStart = sRequest.indexOf(sGetstart);
if (iStart>=0)
iStart+=+sGetstart.length();
iEndSpace = sRequest.indexOf(" ",iStart);
iEndQuest = sRequest.indexOf("?",iStart);
// are there parameters?
if(iEndSpace>0)
if(iEndQuest>0)
// there are parameters
sPath = sRequest.substring(iStart,iEndQuest);
sParam = sRequest.substring(iEndQuest,iEndSpace);
else
// NO parameters
sPath = sRequest.substring(iStart,iEndSpace);
// format the html response
String sResponse,sResponse2,sHeader;
// Update LCD with text from Web
//_________________________________________________________________
// /ajax_inputs&L1=123456789&L2=abcdefghi&nocache=968337.7823963541
// 1-9 on Line 1 and a - i on line 2
if (sPath.startsWith("/ajax_inputs&L1="))
ulReqcount++;
tmtxt1="";
tmtxt2="";
got_text = true; // print the received text to the LCD if found
File in = SPIFFS.open("/temp.txt", "w");
if (in) {
in.print(sPath);
in.close();
else {
lcd.clear();
lcd.print("rOr Temp.TXT");
while(1);
in = SPIFFS.open("/temp.txt", "r");
in.setTimeout(0);
String Dtmtxt = in.readStringUntil('=');
tmtxt1 += in.readStringUntil('&');
tmtxt2 += in.readStringUntil('&');
in.close();
tmtxt1.replace("%20", " ");
tmtxt2.replace("%20", " ");
DisTeXt0 = tmtxt1;
if (tmtxt2==""){
neWTime();
DisTeXt1 = TMnow;
}else{
DisTeXt1 = tmtxt2;
lInE1();
if (sPath.startsWith("/pixel_inputs&L1="))
ulReqcount++;
tmtxt1="";
tmtxt2="";
if (in) {
in.print(sPath);
in.close();
else {
lcd.clear();
while(1);
in.setTimeout(0);
in.close();
if (tmtxt1 == "animate"){emailbutton = "Send";}
DisTeXt0 = tmtxt1;
DisTeXt1 = tmtxt2;
lInE1();
// format the html page for LCD Input /
if(sPath=="/")
ulReqcount++;
sResponse = F("<html>\n<head>\n<title>Environment Monitor Text to LCD</title>\n<script>\n\n");
sResponse += F("strLine1 = \"\";\nstrLine2 = \"\";\n\nfunction SendText()\n{\nnocache = \"&nocache=\" + Math.random() * 1000000;\nvar request = new XMLHttpRequest();\n\nstrLine1 = \"&L1=\" + document.getElementById(\"txt_form\").line1LCD.value;\nstrLine2 = \"&L2=\" + document.getElementById(\"txt_form\").line2LCD.value;\n\n");
sResponse += F("request.open(\"GET\", \"ajax_inputs\" + strLine1 + strLine2 + nocache, true);\nrequest.send(null);\n}\n</script>\n<body>\n<h1>Environment Monitor<BR>LCD Text Input</h1>\n");
sResponse += F("<BR><a href=\"/graphic2\">Pressure Graph Page</a><BR><a href=\"/pressure\">Pressure Gauge Page</a><BR><a href=\"/monitor\">Sensor Gauge Page</a><BR><a href=\"/graphic\">Sensor Graph Page</a><BR><a href=\"/table\">Sensor Datalog Page</a><BR><a href=\"/diag\">Diagnostics Information Page</a><BR>\n");
sResponse += F("<body onload=\"GetESP8266IO()\">\n<h1><FONT SIZE=-1>Enter text to send to ESP81266 LCD:</h1>\n<form id=\"txt_form\" name=\"frmText\">\n<label>Line 1: <input type=\"text\" name=\"line1LCD\" size=\"40\" maxlength=\"40\" /></label><br /><br />\n<label>Line 2: <input type=\"text\" name=\"line2LCD\" size=\"40\" maxlength=\"40\" /></label>\n");
sResponse += F("</form>\n<br />\n<input type=\"submit\" value=\"Send Text\" onclick=\"SendText()\" />\n\n");
sResponse2 = F("<font color=\"#000000\"><body bgcolor=\"#d0d0f0\"><meta name=\"viewport\" content=\"width=device-width, initial-scale=1.0, user-scalable=yes\"><BR>LCD Text Input<BR>\n");
sResponse2 += F("</div>\n<div style=\"clear:both;\"></div><p>");
sResponse2 += MakeHTTPFooter().c_str();
// Send the response to the client
client.print(MakeHTTPHeader(sResponse.length()+sResponse2.length()).c_str());
client.print(sResponse);
client.print(sResponse2);
else if(sPath=="/lights")
ulReqcount++;
sResponse += F("request.open(\"GET\", \"pixel_inputs\" + strLine1 + strLine2 + nocache, true);\nrequest.send(null);\n}\n</script>\n<body>\n<h1>Environment Monitor<BR>LCD Text Input</h1>\n");
else if(sPath=="/yfireset")
ulReqcount++;
client.println("HTTP/1.1 200 OK");
client.println("Content-Type: text/html");
client.println("Connection: close");
client.println();
client.println("<!DOCTYPE HTML>");
client.print("<html><head><title>Environment Monitor</title></head><body>");
client.print("<font color=\"#000000\"><body bgcolor=\"#d0d0f0\">");
client.print("<meta name=\"viewport\" content=\"width=device-width, initial-scale=1.0, user-scalable=yes\">");
client.print("<h1>Environment Monitor<BR>WiFi Reset Page </h1><BR><a href=\"/graphic2\">Pressure Graph Page</a><BR><a href=\"/pressure\">Pressure Gauge Page</a>");
client.print("<BR><a href=\"/monitor\">Sensor Gauges Page</a><BR><a href=\"/graphic\">Sensor Graph Page</a><BR><a href=\"/table\">Sensor Datalog Page</a><BR><BR><BR><BR>Restarted WiFiConnections = ");
client.print(ulReconncount);
client.print("<BR><FONT SIZE=-2>environmental.monitor.log@gmail.com<BR><FONT SIZE=-2>ESP8266 With DHT11 & BMP180 Sensors<BR>");
client.print("<FONT SIZE=-2>Compiled Using ver. 1.6.5-1160-gef26c5f, built on Sep 30, 2015<BR>");
client.println("<IMG SRC=\"https://raw.githubusercontent.com/genguskahn/ESP8266-For-DUMMIES/master/SoC/DimmerDocs/organicw.gif\" WIDTH=\"250\" HEIGHT=\"151\" BORDER=\"1\"></body></html>");
WiFiStart();
else if(sPath=="/diag")
float servolt1 = ESP.getVcc();
long int spdcount = ESP.getCycleCount();
delay(1);
long int spdcount1 = ESP.getCycleCount();
long int speedcnt = spdcount1-spdcount;
FlashMode_t ideMode = ESP.getFlashChipMode();
ulReqcount++;
String duration1 = " ";
int hr,mn,st;
mn = st / 60;
hr = st / 3600;
st = st - mn * 60;
mn = mn - hr * 60;
duration1 += (hr);
duration1 += (":");
duration1 += (mn);
duration1 += (":");
duration1 += (st);
client.println();
client.print("<h1>Environment Monitor<BR>SDK Diagnostic Information</h1><BR><a href=\"/graphic2\">Pressure Graph Page</a><BR><a href=\"/pressure\">Pressure Gauge Page</a>");
client.print("<BR><a href=\"/monitor\">Sensor Gauges Page</a><BR><a href=\"/graphic\">Sensor Graph Page</a><BR><a href=\"/table\">Sensor Datalog Page</a><BR><a href=\"/\">Monitor LCD Text Input Page</a><BR>Restarted WiFiConnections = ");
String diagdat="";
diagdat+=ulReconncount;
diagdat+="<BR> Web Page Requests = ";
diagdat+=ulReqcount;
diagdat+="<BR> WiFi Station Hostname = ";
diagdat+=wifi_station_get_hostname();
diagdat+="<BR> Free RAM = ";
client.print(diagdat);
client.print((uint32_t)system_get_free_heap_size()/1024);
diagdat=" KBytes<BR> Logged Sample Count = ";
diagdat+=ulMeasCount;
diagdat+="<BR> Total Sample points in 24 Hours = 1440<BR> Minimum Sample Logging Interval = 1 Minutes<BR> SDK Version = ";
diagdat+=ESP.getSdkVersion();
diagdat+="<BR> Boot Version = ";
diagdat+=ESP.getBootVersion();
diagdat+="<BR> Free Sketch Space = ";
diagdat+=ESP.getFreeSketchSpace()/1024;
diagdat+=" KBytes<BR> Sketch Size = ";
diagdat+=ESP.getSketchSize()/1024;
diagdat+=" KBytes<BR>";
client.printf(" Flash Chip id = %08X\n", ESP.getFlashChipId());
client.print("<BR>");
client.printf(" Flash Chip Mode = %s\n", (ideMode == FM_QIO ? "QIO" : ideMode == FM_QOUT ? "QOUT" : ideMode == FM_DIO ? "DIO" : ideMode == FM_DOUT ? "DOUT" : "UNKNOWN"));
diagdat="<BR> Flash Size By ID = ";
diagdat+=ESP.getFlashChipRealSize()/1024;
diagdat+=" KBytes<BR> Flash Size (IDE) = ";
diagdat+=ESP.getFlashChipSize()/1024;
diagdat+=" KBytes<BR> Flash Speed = ";
diagdat+=ESP.getFlashChipSpeed()/1000000;
diagdat+=" MHz<BR> ESP8266 CPU Speed = ";
diagdat+=ESP.getCpuFreqMHz();
diagdat+=" MHz<BR>";
client.printf(" ESP8266 Chip id = %08X\n", ESP.getChipId());
diagdat="<BR> System Instruction Cycles Per Second = ";
diagdat+=speedcnt*1000;
diagdat+="<BR> Last System Restart Time = ";
diagdat+=MyNtP;
diagdat+="<BR> Last System Restart Reason = ";
diagdat+=ESP.getResetInfo();
diagdat+="<BR> System Time = ";
diagdat+=TMnow;
diagdat+=" (Last Recorded Sample Time)<BR> System VCC = ";
diagdat+=servolt1/1000, 3;
diagdat+=" V <BR> Datalog File Size in Bytes = N/A";
//diagdat+=Dfsize;
diagdat+="<BR> System Uptime =";
diagdat+=duration1;
client.print("<BR><FONT SIZE=-2>environmental.monitor.log@gmail.com<BR><FONT SIZE=-2>ESP8266 With DHT11 & BMP180 Sensors<BR><FONT SIZE=-2>Compiled Using ver. 1.6.5-1160-gef26c5f, built on Sep 30, 2015<BR>");
diagdat="";
else if(sPath=="/srestart")
client.println();
client.print("<h1>Environment Monitor<BR>Please wait 10 Seconds......<BR><FONT SIZE=+2>System Reset Page !!!! </h1><BR><a href=\"/graphic2\">Pressure Graph Page</a><BR><a href=\"/pressure\">Pressure Gauge Page</a>");
client.print("<BR><a href=\"/monitor\">Sensor Gauges Page</a><BR><a href=\"/graphic\">Sensor Graph Page</a><BR><a href=\"/table\">Sensor Datalog Page</a><BR><a href=\"/diag\">Diagnostics Information Page</a><BR><a href=\"/\">Monitor LCD Text Input Page</a><BR><BR><BR><BR>Restarted WiFiConnections = ");
client.print("<BR><BR><BR><FONT SIZE=-2>environmental.monitor.log@gmail.com<BR><FONT SIZE=-2>ESP8266 With DHT11 & BMP180 Sensors<BR>");
client.stop();
wsysreset();
else
// 404 for non-matching path
sResponse="<html><head><title>404 Not Found</title></head><body><h1>Not Found</h1><p>The requested URL was not found on this server, What did you sk for?.</p></body></html>";
ulReqcount++;
sHeader = F("HTTP/1.1 404 Not found\r\nContent-Length: ");
sHeader += sResponse.length();
client.print(sHeader);
// and stop the client
client.stop();
void FadeInFadeOutRinseRepeat(uint8_t peak)
if (effectState == 0)
for (uint8_t pixel = 0; pixel < pixelCount; pixel++)
uint16_t time = random(800,1000);
strip.LinearFadePixelColor(time, pixel, RgbColor(random(peak), random(peak), random(peak)));
else if (effectState == 1)
uint16_t time = random(600,700);
strip.LinearFadePixelColor(time, pixel, RgbColor(0, 0, 0));
effectState = (effectState + 1) % 2; // next effectState and keep within the number of effectStates
void PickRandom(uint8_t peak)
// pick random set of pixels to animate
uint8_t count = random(pixelCount);
while (count > 0)
uint8_t pixel = random(pixelCount);
// configure the animations
RgbColor color; // = strip.getPixelColor(pixel);
color = RgbColor(random(peak), random(peak), random(peak));
uint16_t time = random(100,400);
strip.LinearFadePixelColor( time, pixel, color);
count--;
void LoopAround(uint8_t peak, uint16_t speed)
// Looping around the ring sample
uint16_t prevPixel;
RgbColor prevColor;
// fade previous one dark
prevPixel = (effectState + (pixelCount - 5)) % pixelCount;
strip.LinearFadePixelColor(speed, prevPixel, RgbColor(0, 0, 0));
prevPixel = (effectState + (pixelCount - 4)) % pixelCount;
prevColor = strip.GetPixelColor( prevPixel );
prevColor.Darken(prevColor.CalculateBrightness() / 2);
strip.LinearFadePixelColor(speed, prevPixel, prevColor);
prevPixel = (effectState + (pixelCount - 3)) % pixelCount;
prevPixel = (effectState + (pixelCount - 2)) % pixelCount;
prevPixel = (effectState + (pixelCount - 1)) % pixelCount;
// fade current one light
strip.LinearFadePixelColor(speed, effectState, RgbColor(random(peak), random(peak), random(peak)));
effectState = (effectState + 1) % pixelCount;
void SetRandomSeed()
uint32_t seed;
// random works best with a seed that can use 31 bits
// analogRead on a unconnected pin tends toward less than four bits
seed = analogRead(0);
delay(1);
for (int shifts = 3; shifts < 31; shifts += 3)
seed ^= analogRead(0) << shifts;
delay(1);
// Serial.println(seed);
randomSeed(seed);
