robotmaker42 wrote:I mashed the web update example, the FSwebBrowser example, and some code I wrote myself. when a file is downloaded to the esp8266( has to be some form of text EX: .txt , .html) it prints it to serial
Hello robotmaker42,
Thank you very much for this good program. The GUI form is excellent.
I extended it, to show in the setup block the contents of the SPIFFS. I added:
// outside of the Arduino blocks
#define DBG_OUTPUT_PORT Serial
//format bytes
String formatBytes(size_t bytes){
if (bytes < 1024){
return String(bytes)+"B";
} else if(bytes < (1024 * 1024)){
return String(bytes/1024.0)+"KB";
} else if(bytes < (1024 * 1024 * 1024)){
return String(bytes/1024.0/1024.0)+"MB";
} else {
return String(bytes/1024.0/1024.0/1024.0)+"GB";
// in Arduino setup(), at the end
if (!SPIFFS.begin()) { DBG_OUTPUT_PORT.println("SPIFFS failed");
} else {
Dir dir = SPIFFS.openDir("/");
while (dir.next()) {
String fileName = dir.fileName();
size_t fileSize = dir.fileSize();
DBG_OUTPUT_PORT.printf("FS File: %s, size: %s\n", fileName.c_str(), formatBytes(fileSize).c_str());
DBG_OUTPUT_PORT.printf("\n");
Unfortunately after flashing the file, I got always a watchdog reset, in Seriell Monitor I can read:
ets Jan 8 2013,rst cause:4, boot mode:(1,6)
wdt reset
see: http://bbs.espressif.com/viewtopic.php?t=1069
Regards, Rudolf
ets Jan 8 2013,rst cause:2, boot mode:(1,7)
ets Jan 8 2013,rst cause:4, boot mode:(1,7)
wdt reset
For that message you can find:
So, better do not use ESP.restart()
Regards, Rudolf
Rudolf wrote:robotmaker42 wrote:I mashed the web update example, the FSwebBrowser example, and some code I wrote myself. when a file is downloaded to the esp8266( has to be some form of text EX: .txt , .html) it prints it to serial
Hello robotmaker42,
I extended it, to show in the setup block the contents of the SPIFFS. I added:Code: Select all// outside of the Arduino blocks
//format bytes
if (bytes < 1024){
} else {
} else {
wdt reset
Regards, Rudolf
thats cool!
