By ProAce
#34438 Hey guys,
I'm hoping you can help me figure out how to make this project work. The idea is that we build a sensor glove which helds five bend sensors, an arduino nano and an ESP8266-01. On the other end we have an InMoov 3D Hand, five servo's, another arduino nano and another ESP8266-01. The set-up works flawless and the only problem we get is with the ESP's sending data to one another. We now do it on the way described in the code below:
Sender:
Code: Select all#include <SoftwareSerial.h>
#define DEBUG true
int bendsensor1 = A0;
int bendsensor2 = A1;
int val1=0;
int val2=0;
SoftwareSerial esp8266(2, 3);
void setup()
  Serial.begin(9600);
  esp8266.begin(115200);
  sendData("AT+RST\r\n", 2000, DEBUG);
  sendData("AT+CIOBAUD=9600\r\n", 2000, DEBUG);
  esp8266.begin(9600);
  sendData("AT+CWMODE=3\r\n", 2000, DEBUG);
  sendData("AT+CWJAP=\"test\",\"test\"\r\n", 2000, DEBUG);
  delay(15000);
  sendData("AT+CIPSTART=\"TCP\",\"192.168.10.10\",80\r\n", 2000, DEBUG);
void loop()
  val1=analogRead(bendsensor1);
  val2=analogRead(bendsensor2);
  sendData("AT+CIPSEND=3\r\n", 100, DEBUG);
  Serial.println(val1);
  sendData("AT+CIPSEND=1\r\n", 100, DEBUG);
  Serial.println(val2);
And the serial output would look like:
Code: Select allAT+CWMODE=3
OK
AT+CWJAP="test","test"
WIFI DISCONNECT
WIFI CONNECTED
WIFI DISCONNECT
WIFI CONNECTED
WIFI GOT IP
AT+CIPSTART="TCP","192.168.10.10",80
ERROR
CLOSED
AT+CIPSEND=3
link is not valid
ERROR
724
AT+CIPSEND=1
link is not valid
ERROR
0
Receiver:
#define DEBUG true
void setup()
  Serial.begin(9600);
  sendData("AT+CWMODE=3\r\n", 50, DEBUG);
  sendData("AT+CWSAP=\"test\",\"test\",1,0\r\n", 50, DEBUG);
  sendData("AT+CIPAP=\"192.168.10.10\"\r\n", 50, DEBUG);
  sendData("AT+CIPMUX=1\r\n", 50, DEBUG);
  sendData("AT+CIPSERVER=1,80\r\n", 50, DEBUG);
  sendData("AT+CIFSR\r\n", 50, DEBUG);
  sendData("+IPD", 50, DEBUG);
void loop()
OK
AT+CWSAP="test","test",1,0
OK
AT+CIPAP="192.168.10.10"
OK
AT+CIPMUX=1
OK
AT+CIPSERVER=1,80
OK
AT+CIFSR
+CIFSR:APIP,"192.168.10.10"
+CIFSR:APMAC,bé&#8226;é¢Ò2Ñ:74:dc"
+CIFSR:STAIP,"0.0.0.0"
+CIFSR:STAMAC,"18:fe:34:f4:74:dc"
OK
+IPD
Does anyone see what the problem could be? Or does anyone know if there is another way to send this data? And how fast can I make this sending?
