I recieve packet [c25.5/1698/43654/74/12] every 8 seconds
uart setup and on are in section 1
The call back is in section 2
NOTE the print(S:) if I enable it I appear to recieve all call backs ...
If disabled I see the 1st call back, the serial buffer contains the others....
Tested @ 9600 and 38400 baud
USING SDK 1.4.0 any suggestions appreciated.....
--- SECTION 1 ---
function c_server()
do_next = nocode -- just in case timewaste
uart.setup(0,38400,0,1,0)
sv=net.createServer(net.TCP, 30) --create server
sv:listen(80,function(c) --listen on port 80
uart.on("data", "\n",uartRX,0)
c:on("sent", Send80)
c:on("receive", Rcv80) --when rcv do function rcv99
end)
[c25.5/1698/43654/74/12] -- this packet arrives every 8 seconds
--- SECTION 2 ---
function uartRX(sdin)
--print("S:") -- with this disabled it appears that only 1 call back occurs.
-- with this ENABLED it appears that only ALL call backs occur.
if string.sub(sdin,1,2)=="nh" then vt.heap = node.heap() end
if #sdin <= 2 then return end --was only crlf
if string.sub(sdin,1,2)=="[c" then
cx = string.find(sdin,"/")
vt.cdeg0 = string.sub(sdin,3,cx-1)
sdin = string.sub(sdin,cx+1,#sdin)
vt.ppm0 = string.sub(sdin,1,cx-1)
vt.apc0 = string.sub(sdin,1,cx-1)
