Which showed the lowest temperature is 1 degree
Now is -2 degrees, and DHT shows 1 degree
init.lua
-- thingspeak.com client with sensor DHT11,DHT22
-- Tested with Lua NodeMCU 0.9.6 (nodemcu_float_0.9.6-dev_20150704.bin)
-- Minimal period for data send to api.thingspeak.com is 15s
DEBUGPRINT = true -- true: enable debugg print, false: disable debugg print
WRITEKEY="xxxxxxxxxxxxxxx" -- set your thingspeak.com key
ssid="xxxxxx" -- your router SSID
pass="xxxxxxxxxx" -- your router password
pin=4 -- number of pin (GPIO0), where is DHTXX connected
prs=60 -- period reading and sending sensors [s]
wifi.setmode(wifi.STATION)
wifi.sta.config(ssid,pass,1)
function debugprint(...)
if DEBUGPRINT then
print(...)
end
end
--Read DHTXX sensor
function ReadDHT()
status,temp,humi,temp_decimial,humi_decimial = dht.read(pin)
if( status == dht.OK ) then
debugprint("DHT Temperature:"..temp..";".."Humidity:"..humi)
elseif( status == dht.ERROR_CHECKSUM ) then
debugprint( "DHT Checksum error." );
elseif( status == dht.ERROR_TIMEOUT ) then
debugprint( "DHT Time out." );
end
end
-- send data to https://api.thingspeak.com
function SendTS()
conn = net.createConnection(net.TCP, 0)
conn:connect(80,'api.thingspeak.com') -- This row is good, but only for newer firmware
--conn:connect(80,'184.106.153.149') -- This is worse, but it also works well with the older firmware.
conn:on("connection",
function(conn) debugprint("Connection!")
conn:send('GET /update?key='..WRITEKEY..
'&headers=false'..
'&field2='..humi..
'&field3='..temp..
' HTTP/1.1\r\n'..
'Host: api.thingspeak.com\r\nAccept: */*\r\nUser-Agent: Mozilla/4.0 (compatible; esp8266 Lua; Windows NT 5.1)\r\n\r\n')
end)
conn:on("sent",
function(conn)
debugprint("Sent!")
if DEBUGPRINT == false
then
conn:close()
end
end)
conn:on("receive",
function(conn, payload)
debugprint("Receive!")
debugprint(payload)
conn:close()
end)
conn:on("disconnection",
function(conn)
debugprint("Disconnection!")
end)
end
-- first reading sensors
ReadDHT()
SendTS()
-- Periodic reading of the sensor
tmr.alarm(0,prs*1000,1,
function()
if wifi.sta.getip()==nil
then
print("IP refresh")
print("!!!!!!!!!!!!!!")
node.restart()
end
ReadDHT()
SendTS()
end)
dht11.lua
-- DHT11 module for ESP8266 with nodeMCU
-- Written by Javier Yanez
-- but based on a script of Pigs Fly from ESP8266.com forum
-- MIT license, http://opensource.org/licenses/MIT
local moduleName = ...
local M = {}
_G[moduleName] = M
local humidity
local temperature
local checksum
local checksumTest
local checko1
local checko2
function M.read(pin)
humidity = 0
temperature = 0
checksum = 0
checko1=0
checko2=0
-- Use Markus Gritsch trick to speed up read/write on GPIO
gpio_read = gpio.read
gpio_write = gpio.write
bitStream = {}
for j = 1, 40, 1 do
bitStream[j] = 0
end
bitlength = 0
-- Step 1: send out start signal to DHT11
gpio.mode(pin, gpio.OUTPUT)
gpio.write(pin, gpio.HIGH)
tmr.delay(100)
gpio.write(pin, gpio.LOW)
tmr.delay(20000)
gpio.mode(pin, gpio.INPUT)
-- Step 2: DHT11 send response signal
-- bus will always let up eventually, don't bother with timeout
while (gpio_read(pin) == 0 ) do end
c=0
while (gpio_read(pin) == 1 and c < 100) do c = c + 1 end
c=0
-- Step 3: DHT11 send data
for j = 1, 40, 1 do
while (gpio_read(pin) == 1 and bitlength < 10 ) do
bitlength = bitlength + 1
end
bitStream[j] = bitlength
bitlength = 0
while (gpio_read(pin) == 0) do end
end
--DHT data acquired, process.
for i = 1, 8, 1 do
if(bitStream[i+0]>2)then
humidity=humidity+2^(8-i)
end
if(bitStream[i+8]>2)then
checko1=checko1+2^(8-i)
end
if(bitStream[i+16]>2)then
temperature=temperature+2^(8-i)
end
if(bitStream[i+24]>2)then
checko2=checko2+2^(8-i)
end
if (bitStream[i+32]>2)then
checksum=checksum+2^(8-i)
end
end
checksumTest=(humidity+checko1+temperature+checko2)%256
-- convert to negative format
--if temperature > 0x8000 then temperature = -(temperature - 0x8000)
--end
if checksum ~= checksumTest then
humidity = -1
end
end
function M.getTemperature()
return temperature
end
function M.getHumidity()
return humidity
end
return M
My chanel https://thingspeak.com/channels/56111 black charts Temperatura
