Moderator: Mmiscool
By iw2fvo
#35198 Thanks for the suggestion.
my terminal shows the followeing after esp power-on_
´ tô(É fC[ý$<p¬æESP Basic 1.60
1
2
3
4
5
6
7
8
9
10
11
12
Failed Wifi Connect
Creating WIFI access point
ESP
APname
APpass
Starting Default Program
Done...
Thanks
By Mmiscool
#35211 512k is the correct size for the esp-01.
To get your module connected to your wifi go to the settings page and enter the information in the filed for station mode. Please note that network names and passwords are case sensitive.
You must restart the module before it will connect to your network.
By heckler
#35213 I believe the 1...12 is showing attempts to connect to your home router.
when you see
Failed Wifi Connect
that tells you that it failed to connect as a station to your home router and it is defaulting back to an AP so you can connect to it as an ap at 192.168.4.1 and check or change the settings.
Which, by the way, is a very cool feature to always allow you to easily connect to it one way (AP) or the other (Station)
dwight
