I'm wondering if there are experiences using relais straight connected to the NodeMCU.
I do read that all relais available needs at least 5V at power.
What happens If I connect relais power tot 3.3V of the NodeMCU? Is the relais still working?
Explore... Chat... Share...
krzychb wrote:@canedje - expanding on lethe's answer I would use a relay module like this
Such module has a transistor, opto-coupler and flyback diode.
You may need to add a separate 5V power supply if using 5V from NodeMCU's USB is causing module resets.
Happy hacking
Krzysztof
