By Petervdpol
#35585 I have hooked up a DHT11 with a ESP8266-01 The ESP sends the data to my Raspberry with MQTT. I use the Arduino IDE for programming. Initially I had the delay in the loop on 5000 (5 seconds) and all works fine. However: I do not need that much data; a reading every two minutes or so would be wonderful and more then enough to create nice charts. So I upped the Delay() in the void loop section and the ESP stops working after sending one message at boot-up when the power is reconnected. So I started with 30000 mil sec, didn't work. I have narrowed it down to 21000 mil sec (21 seconds) which works fine but still way to much data for my liking... What am I doing wrong?
My sketch:
Code: Select all#include <PubSubClient.h>
#include <DHT.h>
const char* ssid = "Yggdrasil";
const char* password = "XXXXXXXXX";
char* topic_t = "openhab/esp8266-1/temp";
char* topic_h = "openhab/esp8266-1/vocht";
char* server = "192.168.XXX.XXX";
String clientName = "esp8266-1";
#define DHTPIN 2 // what pin we're connected to
#define DHTTYPE DHT11 // DHT 11
DHT dht(DHTPIN, DHTTYPE,15);
WiFiClient wifiClient;
PubSubClient client(server, 1883, callback, wifiClient);
void callback(char* topic, byte* payload, unsigned int length) {
// handle message arrived
delay(10);
dht.begin();
Serial.println(ssid);
WiFi.begin(ssid, password);
Serial.println("");
Serial.print(server);
Serial.print(" as ");
Serial.println(clientName);
if (client.connect((char*) clientName.c_str())) {
Serial.println("Connected to MQTT broker");
Serial.print("Topic is: ");
Serial.println(topic_t);
Serial.println(topic_h);
else {
Serial.println("MQTT connect failed");
Serial.println("Will reset and try again...");
abort();
float h = dht.readHumidity();
float t = dht.readTemperature();
if (isnan(h) || isnan(t)) {
Serial.println("Failed to read from DHT sensor!");
return;
static int counter = 0;
String payload ;
payload += t;
//payload += ":";
//payload += h;
String payloadh ;
payloadh += h;
if (client.connected()){
Serial.print("Sending payload: ");
Serial.println(payload);
if (client.publish(topic_t, (char*) payload.c_str()))
Serial.println("Publish ok");
else {
Serial.println("Publish failed");
//peter
Serial.println(payloadh);
if (client.publish(topic_h, (char*) payloadh.c_str()))
else {
//peter
else {
++counter;
delay(21000);
By Mario Mikočević
#35586 Try this ->
Code: Select all#include <Ticker.h>
Ticker tickerSensorScan;
#define WAITTIME 300
boolean tickerFired;
void flagSensorScan( void ) {
  tickerFired = true;
  tickerSensorScan.attach( WAITTIME, flagSensorScan );
  tickerFired = true;
  if( tickerFired ) {
    tickerFired = false;
    doSomethingWithSensor();
