Chat freely about anything...
By El Torote
#36547 Greetings!! would you guys be kind enough to confirm if I am going to remove the correct cap from the board? the first component that is between the external antenna port and the rectangular board antenna. Thanks in advanced.
By dynek
#36612
El Torote wrote:Greetings!! would you guys be kind enough to confirm if I am going to remove the correct cap from the board? the first component that is between the external antenna port and the rectangular board antenna. Thanks in advanced.
I can confirm you should read the whole thread :-)
For instance this message and the one that follows: viewtopic.php?f=6&t=1550&start=12#p35599
By Shivank
#54330 Hi all,
I removed the stated resistor,
it is still connecting to internet and uploading data online.
I think the ceramic antenna is not disconnected.
What should I do to disconnect it?
I only need an external antenna slot.
