Chat freely about anything...
By cyberteen
#35887 Hi guys,
I have this ESP8266-12 Test board, like the one in this link: http://blog.squix.ch/2015/01/esp8266-te ... eview.html
I have been playing it for the past one week. All long, i was using the firmware 0.9.2.2 using ESP_flasher tool. I could use the AT commands and everything was working fine.
I wanted to upgrade to the latest one, found in the expressif github page: https://github.com/espressif/ESP8266_AT/tree/master/bin
After that I've been encountering this weird problem:
I am powering the module with 3 AA batteries, which has about 3.4V now. But when i power the esp8266, the voltage shows 2.9v and is constantly decreasing, ultimately the power leds keep on dimming until the board gets fully switched off.
If I take out one battery for about 5 mins, and put it back, it again glows brightly slowly losing voltage until it again shuts down.
While it is powered up, I am still able to flash firmwares to it, but i get only garbage at some random baud rates.
I dont know what to do now. All my connections are correct, and I could very well use the ESP. I dont know whats causing the problem now.!
Please help me out.
By cyberteen
#35976 Ah! Yes.! Thanks a lot! Replaced the board with a fresh set of batteries. Its working good now!
Since this happened right after flashing the new firmware, I got freaked out! Maybe I should switch to rechargeable AA batteries or use a 5V DC adapter and regulate it to 3.3 V.
