i'm trying to create a client, client/server, server system.
in the middle ESP i want to use AP_STA mode, and he need to connect to the server and be a server for the other client.
i have a messy code but the big problem i'm thinking is the ip... anyone do it before? can i see a working code?
this is my client/server code:
#include <ESP8266WebServer.h>
#include <WiFiClient.h>
const char *ssid = "MyESPAP";
const char *password = "MyPassword";
const char *host = "192.168.4.1";
const char *ssid1 = "MyESPAPSERVER";
const char *password1 = "MyPasswordSERVER";
const char *host1 = "10.10.10.1";
ESP8266WebServer server(80);
int led = 2;
int blink_count = 0;
int blink_rate = 250;
int value_from_client = 0;
String client_to_server = "";
void handleRoot() {
server.send(200, "text/html", "<html><body><h1>MyESPAP Home Page</h1>\r\n<a href=\"/frate\">Fast Rate</a><br>\r\n<a href=\"/srate\">Slow Rate</a><br><h2 href=\"/Msg\">num from client = </h2><br>\r\n</body></html>");
void handleMSG() {
blink_rate =250;
String num_from_client = server.arg("ClientNum");
server.send(200, "text/html", "<html><head><script>window.onload = function() { setInterval(function() {window.location.replace('/');}, 1000); };</script></head><body><h1>MSG mode</h1>Got " + num_from_client + " from client</body></html>");
//Serial.println(num_from_client);
String cloud = "AT#DWSEND=0,property.publish,key,gas,value," + num_from_client;
Serial.println(cloud);
delay(5);
client_to_server = num_from_client;
value_from_client=(num_from_client.toInt());
//Serial.println(value_from_client);
int rate_toogle = 0;
int client_num_val = 0;
delay(10);
WiFi.softAP(ssid1, password1);
Serial.println(ssid);
WiFi.mode(WIFI_AP_STA);
WiFi.begin(ssid, password);
Serial.println("");
server.on("/Msg", handleMSG);
server.begin();
server.handleClient();
delay(8000);
if (rate_toogle == 0)
rate_toogle = 1;
else
rate_toogle = 0;
Serial.println(host);
WiFiClient client;
const int httpPort = 80;
return;
// String url = "/frate";
// if (rate_toogle == 0)
// url = "/srate";
// Serial.print("Requesting URL: ");
// Serial.println(url);
// client.print(String("GET ") + url + " HTTP/1.1\r\n" + "Host: " + host + "\r\n" + "Connection: close\r\n\r\n");
// delay(10);
// while(client.available()){
// String line = client.readStringUntil('\r');
// Serial.print(line);
int sensorValue = digitalRead(2);
Serial.println(sensorValue);
if(sensorValue==1)
client_num_val = (sensorValue + client_num_val);
Serial.println(client_num_val);
String url1 = "/Msg";
url1 = url1 + "?ClientNum=" + client_to_server;
//url1 = url1 + " ?ClientNum= " + String(sensorValue);
Serial.println(url1);
client.print(String("GET ") + url1 + " HTTP/1.1\r\n" + "Host: " + host + "\r\n" + "Connection: close\r\n\r\n");
delay(10);
Serial.print(line);
look on the setup....
i forget to tell that i dont konw nothing about IP so maybe the ip is forbidden...
edit: i'm sorry, i found the wifi.APConfig and how to change the ip...
you can remove this post...
best regard,
yoav
