Am I correct that every time the time function is called that an NTP request is sent?
Explore... Chat... Share...
Moderator: Mmiscool
cwilt wrote:Question for the developer...
Mmiscool wrote:When you connect to any wifi network it attempts to get the current time. After that I believe it relights on the internal clock unless the time zone is changed.
