Chat freely about anything...
By martinayotte
#36225 I didn't tried out your sketch, but looking at them, I see few things :
The delay(10) calls in Client are maybe not long enough to received the response from Server, you should add something like :
Code: Select all  int timeout = millis() + 5000;
  while (client.available() == 0) {
    if (timeout - millis() < 0) {
      Serial.println(">>> Client Timeout !");
      client.stop();
      return;
Also, did you tried to put a delay between the GET and the POST ?
Because since the server is not multi-threaded, maybe the POST simply get lost.
