If this is not right another possibility is adding a SD card. I don't know if SD library is compatible with esp8266.
Explore... Chat... Share...
gmag11 wrote:That's true but, as for his comments, I guess he's not going to write always in the same memory position, but sequentially until EPROMs is full so you have to multiply by n times, being n eEPROM size/bytes by sample.
