It power up, both the transmit on it and the esp 01 flash then the lights go out and it dissapears from both the win an osx hardware managers.
I suffer from a bad case of random misfiring synapses!
Explore... Chat... Share...
lethe wrote:Don't power the ESP from the 3.3V output of your serial adapter (I assume that's what you were doing).
Most serial adapters will not supply enough current to the ESP and either brown out the ESP or the serial adapter. Try using a dedicated 3.3V suply.
Timpanogos Slim wrote:The cp2102 can do it, *if it is implemented correctly. That probably comes down to how generous the power traces on the board are, and the use of appropriate bypass capacitors.
Disappearing from the hardware manager sounds like it drew more power than the usb port was prepared to deliver, though.
