By ingeea
#37046 Hello Community,
i am really new to this interesting conponent, i have discovered this chip only yesterday through Research on the Internet. Well what motivates me is that this chip includes 32-bit CPU, is that right? I can also use it as master I²C to Control a sensor slave!! Well this is really very interesting! I have searched a lot and always (Adafruit, espruino...) have i noticed that i can use it with arduino IDE (edit the prog, compile and load to chip), i have installed the the board and i wrote an example Programm(that was on internet) and i have successfully compiled!
So now i would really ask you for my purpose, i want to Control a sensor through I²C and then send data through Wifi, Is that really possible to do only by the use of ESP8266? of what should i Aware be? the Wire library is the same als the included arduino Library, can i really use it? Please Reply me for further info! I want to know more about this chip before starting my Project.
Ah ja! also i can not find the pinout for the ESP8266, i can find only find it on a development board (Adafruit for instance), i want to create my own PCB (ESP8266 and the sensor i want to use) so where can i find the specification from the manufacturer? I think the manufacturer provides the Wifi contoller which includes the 32-bits cpu and a pcb Antenne at least for the Modell ESP-01, is that right?
have a very nice Merry Christmas!
By trackerj
By jgustavoam
#37105 ESP 8266 Interface Reference
http://bbs.espressif.com/viewtopic.php?f=51&t=819
8A_ESP8266_Interface_GPIO_EN_v0.5.pdf
8C-ESP8266__Interface_I2C__EN_v1.0.pdf
ESP8266 Hardware Guide
http://bbs.espressif.com/viewtopic.php? ... 1545#p1545
0A-ESP8266__Datasheet__EN_v4.4.pdf Datasheet of ESP8266EX
3.4. Inter-integrated Circuit Interface (I2C) page 19
