I got one 2 weeks ago and played around with it by connecting it to an Arduino uno and using Arduino serial monitor.It worked fine and responded to all AT commands
However,once I was using AT+CIPSTART command and it was not responding and being the impatient guy I used AT+RST command .Thereafter a load of garbage came on the serial monitor which didn't stop unless I unplugged it from the computer.
Later I flashed it with firmware .However now it doesn't respond to AT+CIPSTART and some other commands
I used this firmware flasher
https://docs.google.com/uc?export=downl ... TIyYURqdGc
What is the problem and solutions
Also if it's a problem of the firmware ,can I get a link that works along with instructions on how to flash .I searched a lot but seem unable to find a suitable one.
