By krzychb
#37446 If there is now winter in place where you live, consider using ESP8266 and some easy to get hardware to control humidity in your home.
I did it. It was fun so here is step by step guide - https://github.com/krzychb/OnlineHumidifier
Check it out, share your charts and have fun as well :D
Krzysztof
P.S. Actually the humidity sensor should be placed away from humidifier. Otherwise desired humidity level may be maintained only in the local area nearby. I put everything close together show all required components.
By Vin708
#37526 Excellent Write up and well documented. I am a new user to the ESP8266 and this looks like an excellent project to learn from.
Thank You for taking the time to document and post this!
Vince
