I modified it because I want to trigger the pushbullet note from a switch linked to my 3D printer so I get a notification when it's finishes.
All works great, I can trigger the message a few times OK but after say 5 min's I try to trigger it again and the serial output doesn't get past "request sent" I assume it's because it's stuck at the
while (client.available() == 0);
but not sure why.
Reset and try again and it works great for a few minutes.
any ideas what I'm doing wrong?
#include <WiFiClientSecure.h>
const char* ssid = "******";
const char* password = "****";
const char* host = "api.pushbullet.com";
const int httpsPort = 443;
const char* PushBulletAPIKEY = "===================="; //get it from your pushbullet account
const int BUTTON = 4; //button input
// Use web browser to view and copy
// SHA1 fingerprint of the certificate
const char* fingerprint = "2C BC 06 10 0A E0 6E B0 9E 60 E5 96 BA 72 C5 63 93 23 54 B3"; //got it using https://www.grc.com/fingerprints.htm
WiFiClientSecure client;
pinMode(BUTTON, INPUT);
pinMode(12, OUTPUT);
pinMode(13, OUTPUT);
pinMode(15, OUTPUT);
Serial.println(ssid);
WiFi.mode(WIFI_STA);
WiFi.begin(ssid, password);
Serial.println("");
// Use WiFiClientSecure class to create TLS connection
Serial.println(host);
if (!client.connect(host, httpsPort)) {
return;
if (client.verify(fingerprint, host)) {
Serial.println("certificate matches");
} else {
Serial.println("certificate doesn't match");
if (digitalRead(BUTTON)==LOW){ // Wait for buton press
String url = "/v2/pushes";
String messagebody = "{\"type\": \"note\", \"title\": \"3D Printer\", \"body\": \"3D Print Finished\"}\r\n";
Serial.print("requesting URL: ");
Serial.println(url);
client.print(String("POST ") + url + " HTTP/1.1\r\n" +
"Host: " + host + "\r\n" +
"Authorization: Bearer " + PushBulletAPIKEY + "\r\n" +
"Content-Type: application/json\r\n" +
"Content-Length: " +
String(messagebody.length()) + "\r\n\r\n");
client.print(messagebody);
Serial.println("request sent");
while (client.available()) {
String line = client.readStringUntil('\n');
Serial.println(line);
I moved the connection code in to the loop that's run when the button is pressed and it works fine now.
Thanks again.
Phil
