It has been a while since dealing with Arduino but I decided to dive back in!
I am following the instructions from:
Tutorial Arduino Firmware Upload
http://www.esp8266.nu/index.php/Tutorial_Arduino_Firmware_Upload
I am receiving the following error when uploading sketches to my NodeMCU ESP8266 via the Arduino IDE v1.6.7. Here is the message I am receiving:
Arduino: 1.6.7 (Windows 7), Board: "NodeMCU 1.0 (ESP-12E Module), 80 MHz, 9600"
WARNING: Category '' in library EEPROM is not valid. Setting to 'Uncategorized'
WARNING: Category '' in library ESP8266httpUpdate is not valid. Setting to 'Uncategorized'
WARNING: Category '' in library Hash is not valid. Setting to 'Uncategorized'
WARNING: Category '' in library SPI is not valid. Setting to 'Uncategorized'
WARNING: Category '' in library Ticker is not valid. Setting to 'Uncategorized'
WARNING: Category '' in library Wire is not valid. Setting to 'Uncategorized'
Warning: platform.txt from core 'ESP8266 Modules' contains deprecated recipe.ar.pattern="{compiler.path}{compiler.ar.cmd}" {compiler.ar.flags} {compiler.ar.extra_flags} "{build.path}/{archive_file}" "{object_file}", automatically converted to recipe.ar.pattern="{compiler.path}{compiler.ar.cmd}" {compiler.ar.flags} {compiler.ar.extra_flags} "{archive_file_path}" "{object_file}". Consider upgrading this core.
C:\Users\Admin\Desktop\Easy IoT\ESPEasy\ESPEasy.ino: In function 'void setup()':
ESPEasy:327: error: 'emergencyReset' was not declared in this scope
emergencyReset();
ESPEasy:329: error: 'LoadSettings' was not declared in this scope
LoadSettings();
ESPEasy:347: error: 'ResetFactory' was not declared in this scope
ResetFactory();
ESPEasy:355: error: 'addLog' was not declared in this scope
addLog(LOG_LEVEL_INFO, log);
ESPEasy:360: error: 'WifiAPconfig' was not declared in this scope
WifiAPconfig();
ESPEasy:361: error: 'WifiConnect' was not declared in this scope
WifiConnect();
ESPEasy:363: error: 'hardwareInit' was not declared in this scope
hardwareInit();
ESPEasy:364: error: 'PluginInit' was not declared in this scope
PluginInit();
ESPEasy:365: error: 'CPluginInit' was not declared in this scope
CPluginInit();
ESPEasy:367: error: 'WebServerInit' was not declared in this scope
WebServerInit();
ESPEasy:379: error: 'getProtocolIndex' was not declared in this scope
byte ProtocolIndex = getProtocolIndex(Settings.Protocol);
ESPEasy:381: error: 'MQTTConnect' was not declared in this scope
MQTTConnect();
ESPEasy:383: error: 'sendSysInfoUDP' was not declared in this scope
sendSysInfoUDP(3);
ESPEasy:395: error: 'readFromRTC' was not declared in this scope
if (readFromRTC(&bootMode))
ESPEasy:407: error: 'saveToRTC' was not declared in this scope
saveToRTC(0);
C:\Users\Admin\Desktop\Easy IoT\ESPEasy\ESPEasy.ino: In function 'void loop()':
ESPEasy:436: error: 'PluginCall' was not declared in this scope
if(!PluginCall(PLUGIN_SERIAL_IN, 0, dummyString))
ESPEasy:437: error: 'serial' was not declared in this scope
serial();
ESPEasy:442: error: 'checkUDP' was not declared in this scope
checkUDP();
ESPEasy:450: error: 'WifiDisconnect' was not declared in this scope
WifiDisconnect();
ESPEasy:469: error: 'FreeMem' was not declared in this scope
sprintf_P(str, PSTR("Uptime %u ConnectFailures %u FreeMem %u"), wdcounter / 2, connectionFailures, FreeMem());
ESPEasy:472: error: 'addLog' was not declared in this scope
ESPEasy:473: error: 'sendSysInfoUDP' was not declared in this scope
sendSysInfoUDP(1);
ESPEasy:474: error: 'refreshNodeList' was not declared in this scope
refreshNodeList();
ESPEasy:475: error: 'MQTTCheck' was not declared in this scope
MQTTCheck();
ESPEasy:483: error: 'PluginCall' was not declared in this scope
PluginCall(PLUGIN_TEN_PER_SECOND, 0, dummyString);
ESPEasy:491: error: 'PluginCall' was not declared in this scope
PluginCall(PLUGIN_ONCE_A_SECOND, 0, dummyString);
ESPEasy:495: error: 'WifiCheck' was not declared in this scope
WifiCheck();
ESPEasy:518: error: 'SensorSend' was not declared in this scope
SensorSend();
ESPEasy:521: error: 'saveToRTC' was not declared in this scope
saveToRTC(1);
ESPEasy:523: error: 'addLog' was not declared in this scope
ESPEasy:529: error: 'delayedReboot' was not declared in this scope
delayedReboot(60);
ESPEasy:531: error: 'backgroundtasks' was not declared in this scope
backgroundtasks();
C:\Users\Admin\Desktop\Easy IoT\ESPEasy\ESPEasy.ino: In function 'void SensorSend()':
ESPEasy:546: error: 'getDeviceIndex' was not declared in this scope
byte DeviceIndex = getDeviceIndex(Settings.TaskDeviceNumber[x]);
ESPEasy:547: error: 'LoadTaskSettings' was not declared in this scope
LoadTaskSettings(x);
ESPEasy:559: error: 'PluginCall' was not declared in this scope
success = PluginCall(PLUGIN_READ, &TempEvent, dummyString);
ESPEasy:576: error: 'Calculate' was not declared in this scope
byte error = Calculate(TmpStr, &result);
ESPEasy:581: error: 'sendData' was not declared in this scope
sendData(&TempEvent);
C:\Users\Admin\Desktop\Easy IoT\ESPEasy\Controller.ino: In function 'boolean sendData(EventStruct*)':
Controller:6: error: 'LoadTaskSettings' was not declared in this scope
LoadTaskSettings(event->TaskIndex);
Controller:7: error: 'getProtocolIndex' was not declared in this scope
Controller:10: error: 'PluginCall' was not declared in this scope
PluginCall(PLUGIN_EVENT_OUT, event, dummyString);
Controller:16: error: 'addLog' was not declared in this scope
addLog(LOG_LEVEL_DEBUG_MORE, log);
C:\Users\Admin\Desktop\Easy IoT\ESPEasy\Controller.ino: In function 'void callback(const MQTT::Publish&)':
Controller:36: error: 'addLog' was not declared in this scope
addLog(LOG_LEVEL_DEBUG, log);
Controller:41: error: 'getProtocolIndex' was not declared in this scope
C:\Users\Admin\Desktop\Easy IoT\ESPEasy\Controller.ino: In function 'void MQTTConnect()':
Controller:66: error: 'addLog' was not declared in this scope
Controller:78: error: 'addLog' was not declared in this scope
addLog(LOG_LEVEL_ERROR, log);
C:\Users\Admin\Desktop\Easy IoT\ESPEasy\Controller.ino: In function 'void MQTTCheck()':
Controller:91: error: 'getProtocolIndex' was not declared in this scope
C:\Users\Admin\Desktop\Easy IoT\ESPEasy\Controller.ino: In function 'boolean nodeVariableCopy(byte, byte)':
Controller:121: error: 'addLog' was not declared in this scope
Controller:133: error: 'addLog' was not declared in this scope
C:\Users\Admin\Desktop\Easy IoT\ESPEasy\Controller.ino: In function 'void checkUDP()':
Controller:233: error: 'addLog' was not declared in this scope
addLog(LOG_LEVEL_DEBUG, packetBuffer);
Controller:234: error: 'ExecuteCommand' was not declared in this scope
ExecuteCommand(packetBuffer);
Controller:264: error: 'addLog' was not declared in this scope
Controller:272: error: 'PluginCall' was not declared in this scope
PluginCall(PLUGIN_UDP_IN, &TempEvent, dummyString);
C:\Users\Admin\Desktop\Easy IoT\ESPEasy\Controller.ino: In function 'void sendSysInfoUDP(byte)':
Controller:308: error: 'addLog' was not declared in this scope
C:\Users\Admin\Desktop\Easy IoT\ESPEasy\Hardware.ino: In function 'void hardwareInit()':
Hardware:11: error: 'addLog' was not declared in this scope
addLog(LOG_LEVEL_INFO,log);
C:\Users\Admin\Desktop\Easy IoT\ESPEasy\Misc.ino: In function 'void SaveSettings()':
Misc:167: error: 'SaveToFlash' was not declared in this scope
SaveToFlash(0, (byte*)&Settings, sizeof(struct SettingsStruct));
C:\Users\Admin\Desktop\Easy IoT\ESPEasy\Misc.ino: In function 'boolean LoadSettings()':
Misc:182: error: 'LoadFromFlash' was not declared in this scope
LoadFromFlash(0, (byte*)&Settings, sizeof(struct SettingsStruct));
C:\Users\Admin\Desktop\Easy IoT\ESPEasy\Misc.ino: In function 'void SaveTaskSettings(byte)':
Misc:196: error: 'SaveToFlash' was not declared in this scope
SaveToFlash(4096 + (TaskIndex * 1024), (byte*)&ExtraTaskSettings, sizeof(struct ExtraTaskSettingsStruct));
C:\Users\Admin\Desktop\Easy IoT\ESPEasy\Misc.ino: In function 'void LoadTaskSettings(byte)':
Misc:212: error: 'LoadFromFlash' was not declared in this scope
LoadFromFlash(4096 + (TaskIndex * 1024), (byte*)&ExtraTaskSettings, sizeof(struct ExtraTaskSettingsStruct));
C:\Users\Admin\Desktop\Easy IoT\ESPEasy\Misc.ino: In function 'void SaveCustomTaskSettings(int, byte*, int)':
Misc:227: error: 'SaveToFlash' was not declared in this scope
SaveToFlash(4096 + (TaskIndex * 1024) + 512, memAddress, datasize);
C:\Users\Admin\Desktop\Easy IoT\ESPEasy\Misc.ino: In function 'void LoadCustomTaskSettings(int, byte*, int)':
Misc:242: error: 'LoadFromFlash' was not declared in this scope
LoadFromFlash(4096 + (TaskIndex * 1024) + 512, memAddress, datasize);
C:\Users\Admin\Desktop\Easy IoT\ESPEasy\Misc.ino: In function 'void SaveToFlash(int, byte*, int)':
Misc:334: error: 'addLog' was not declared in this scope
C:\Users\Admin\Desktop\Easy IoT\ESPEasy\Misc.ino: In function 'void EraseFlash()':
Misc:386: error: 'addLog' was not declared in this scope
C:\Users\Admin\Desktop\Easy IoT\ESPEasy\Misc.ino: In function 'void ResetFactory()':
Misc:402: error: 'readFromRTC' was not declared in this scope
if (readFromRTC(&bootCount))
Misc:416: error: 'saveToRTC' was not declared in this scope
saveToRTC(bootCount);
Misc:469: error: 'WifiDisconnect' was not declared in this scope
WifiDisconnect();
C:\Users\Admin\Desktop\Easy IoT\ESPEasy\Misc.ino: In function 'void addLog(byte, String&)':
Misc:537: error: invalid initialization of non-const reference of type 'String&' from an rvalue of type 'char*'
addLog(loglevel, log);
Misc:533: error: in passing argument 2 of 'void addLog(byte, String&)'
void addLog(byte loglevel, String& string)
C:\Users\Admin\Desktop\Easy IoT\ESPEasy\Serial.ino: In function 'void ExecuteCommand(char*)':
Serial:57: error: 'WifiScan' was not declared in this scope
WifiScan();
Serial:60: error: 'WifiConnect' was not declared in this scope
WifiConnect();
Serial:63: error: 'WifiDisconnect' was not declared in this scope
WifiDisconnect();
C:\Users\Admin\Desktop\Easy IoT\ESPEasy\WebServer.ino: In function 'void WebServerInit()':
WebServer:7: error: 'handle_root' was not declared in this scope
WebServer.on("/", handle_root);
WebServer:8: error: 'handle_config' was not declared in this scope
WebServer.on("/config", handle_config);
WebServer:9: error: 'handle_hardware' was not declared in this scope
WebServer.on("/hardware", handle_hardware);
WebServer:10: error: 'handle_devices' was not declared in this scope
WebServer.on("/devices", handle_devices);
WebServer:11: error: 'handle_log' was not declared in this scope
WebServer.on("/log", handle_log);
WebServer:12: error: 'handle_tools' was not declared in this scope
WebServer.on("/tools", handle_tools);
WebServer:13: error: 'handle_i2cscanner' was not declared in this scope
WebServer.on("/i2cscanner", handle_i2cscanner);
WebServer:14: error: 'handle_wifiscanner' was not declared in this scope
WebServer.on("/wifiscanner", handle_wifiscanner);
WebServer:15: error: 'handle_login' was not declared in this scope
WebServer.on("/login", handle_login);
WebServer:16: error: 'handle_control' was not declared in this scope
WebServer.on("/control", handle_control);
WebServer:17: error: 'handle_download' was not declared in this scope
WebServer.on("/download", handle_download);
WebServer:18: error: 'handle_upload' was not declared in this scope
WebServer.on("/upload", handle_upload);
WebServer:19: error: 'handleFileUpload' was not declared in this scope
WebServer.onFileUpload(handleFileUpload);
WebServer:24: error: 'handle_css' was not declared in this scope
WebServer.on("/esp.css", handle_css);
WebServer:26: error: 'handle_advanced' was not declared in this scope
WebServer.on("/advanced", handle_advanced);
C:\Users\Admin\Desktop\Easy IoT\ESPEasy\WebServer.ino: In function 'void handle_root()':
WebServer:113: error: 'isLoggedIn' was not declared in this scope
if (!isLoggedIn()) return;
WebServer:120: error: 'urlDecode' was not declared in this scope
urlDecode(command);
C:\Users\Admin\Desktop\Easy IoT\ESPEasy\WebServer.ino: In function 'void handle_config()':
WebServer:232: error: 'isLoggedIn' was not declared in this scope
WebServer:256: error: 'urlDecode' was not declared in this scope
urlDecode(tmpString);
C:\Users\Admin\Desktop\Easy IoT\ESPEasy\WebServer.ino: In function 'void handle_hardware()':
WebServer:392: error: 'isLoggedIn' was not declared in this scope
WebServer:409: error: 'addPinSelect' was not declared in this scope
addPinSelect(true, reply, "pini2csda", Settings.Pin_i2c_sda);
C:\Users\Admin\Desktop\Easy IoT\ESPEasy\WebServer.ino: In function 'void handle_devices()':
WebServer:425: error: 'isLoggedIn' was not declared in this scope
WebServer:493: error: 'urlDecode' was not declared in this scope
WebServer:532: error: 'PluginCall' was not declared in this scope
PluginCall(PLUGIN_WEBFORM_SAVE, &TempEvent, dummyString);
WebServer:569: error: 'PluginCall' was not declared in this scope
PluginCall(PLUGIN_GET_DEVICEVALUENAMES, &TempEvent, dummyString);
WebServer:591: error: 'PluginCall' was not declared in this scope
customConfig = PluginCall(PLUGIN_WEBFORM_SHOW_CONFIG, &TempEvent, reply);
WebServer:655: error: 'PluginCall' was not declared in this scope
WebServer:660: error: 'addDeviceSelect' was not declared in this scope
addDeviceSelect(reply, "taskdevicenumber", Settings.TaskDeviceNumber[index - 1]);
WebServer:687: error: 'addPinSelect' was not declared in this scope
addPinSelect(false, reply, "taskdevicepin1", Settings.TaskDevicePin1[index - 1]);
WebServer:692: error: 'addPinSelect' was not declared in this scope
addPinSelect(false, reply, "taskdevicepin2", Settings.TaskDevicePin2[index - 1]);
WebServer:714: error: 'PluginCall' was not declared in this scope
PluginCall(PLUGIN_WEBFORM_LOAD, &TempEvent, reply);
C:\Users\Admin\Desktop\Easy IoT\ESPEasy\WebServer.ino: In function 'void addDeviceSelect(String&, String, int)':
WebServer:770: error: 'sortDeviceArray' was not declared in this scope
sortDeviceArray();
C:\Users\Admin\Desktop\Easy IoT\ESPEasy\WebServer.ino: In function 'void handle_log()':
WebServer:1003: error: 'isLoggedIn' was not declared in this scope
C:\Users\Admin\Desktop\Easy IoT\ESPEasy\WebServer.ino: In function 'void handle_tools()':
WebServer:1040: error: 'isLoggedIn' was not declared in this scope
WebServer:1046: error: 'urlDecode' was not declared in this scope
urlDecode(command);
C:\Users\Admin\Desktop\Easy IoT\ESPEasy\WebServer.ino: In function 'void handle_i2cscanner()':
WebServer:1090: error: 'isLoggedIn' was not declared in this scope
C:\Users\Admin\Desktop\Easy IoT\ESPEasy\WebServer.ino: In function 'void handle_wifiscanner()':
WebServer:1167: error: 'isLoggedIn' was not declared in this scope
C:\Users\Admin\Desktop\Easy IoT\ESPEasy\WebServer.ino: In function 'void handle_login()':
WebServer:1206: error: 'urlDecode' was not declared in this scope
urlDecode(command);
C:\Users\Admin\Desktop\Easy IoT\ESPEasy\WebServer.ino: In function 'void handle_control()':
WebServer:1246: error: 'urlDecode' was not declared in this scope
urlDecode(command);
WebServer:1267: error: 'PluginCall' was not declared in this scope
if (!PluginCall(PLUGIN_WRITE, &TempEvent, webrequest))
C:\Users\Admin\Desktop\Easy IoT\ESPEasy\WebServer.ino: In function 'void handle_advanced()':
WebServer:1282: error: 'isLoggedIn' was not declared in this scope
WebServer:1304: error: 'urlDecode' was not declared in this scope
C:\Users\Admin\Desktop\Easy IoT\ESPEasy\_C005.ino: In function 'boolean CPlugin_005(byte, EventStruct*)':
_C005:52: error: 'PluginCall' was not declared in this scope
PluginCall(PLUGIN_WRITE, &TempEvent, cmd);
_C005:62: error: 'PluginCall' was not declared in this scope
PluginCall(PLUGIN_GET_DEVICEVALUENAMES, event, dummyString);
C:\Users\Admin\Desktop\Easy IoT\ESPEasy\_C006.ino: In function 'boolean CPlugin_006(byte, EventStruct*)':
_C006:63: error: 'PluginCall' was not declared in this scope
_C006:73: error: 'PluginCall' was not declared in this scope
C:\Users\Admin\Desktop\Easy IoT\ESPEasy\_P003_Pulse.ino: In function 'boolean Plugin_003(byte, EventStruct*, String&)':
_P003_Pulse:87: error: 'Plugin_003_pulseinit' was not declared in this scope
Plugin_003_pulseinit(Settings.TaskDevicePin1[event->TaskIndex], event->TaskIndex);
C:\Users\Admin\Desktop\Easy IoT\ESPEasy\_P004_Dallas.ino: In function 'boolean Plugin_004(byte, EventStruct*, String&)':
_P004_Dallas:52: error: 'Plugin_004_DS_scan' was not declared in this scope
byte devCount = Plugin_004_DS_scan(choice, addr);
_P004_Dallas:86: error: 'Plugin_004_DS_scan' was not declared in this scope
byte devCount = Plugin_004_DS_scan(Settings.TaskDevicePluginConfig[event->TaskIndex][0], addr);
_P004_Dallas:117: error: 'Plugin_004_DS_readTemp' was not declared in this scope
if (Plugin_004_DS_readTemp(addr, &value))
C:\Users\Admin\Desktop\Easy IoT\ESPEasy\_P004_Dallas.ino: In function 'byte Plugin_004_DS_scan(byte, uint8_t*)':
_P004_Dallas:152: error: 'Plugin_004_DS_reset' was not declared in this scope
Plugin_004_DS_reset();
_P004_Dallas:154: error: 'Plugin_004_DS_reset_search' was not declared in this scope
Plugin_004_DS_reset_search();
_P004_Dallas:155: error: 'Plugin_004_DS_search' was not declared in this scope
while (Plugin_004_DS_search(tmpaddr))
C:\Users\Admin\Desktop\Easy IoT\ESPEasy\_P004_Dallas.ino: In function 'boolean Plugin_004_DS_readTemp(uint8_t*, float*)':
_P004_Dallas:174: error: 'Plugin_004_DS_reset' was not declared in this scope
_P004_Dallas:175: error: 'Plugin_004_DS_write' was not declared in this scope
Plugin_004_DS_write(0x55); // Choose ROM
_P004_Dallas:189: error: 'Plugin_004_DS_read' was not declared in this scope
ScratchPad[i] = Plugin_004_DS_read();
_P004_Dallas:191: error: 'Plugin_004_DS_crc8' was not declared in this scope
if (Plugin_004_DS_crc8(ScratchPad, 8) != ScratchPad[8])
C:\Users\Admin\Desktop\Easy IoT\ESPEasy\_P004_Dallas.ino: In function 'uint8_t Plugin_004_DS_search(uint8_t*)':
_P004_Dallas:282: error: 'Plugin_004_DS_write' was not declared in this scope
Plugin_004_DS_write(0xF0);
_P004_Dallas:288: error: 'Plugin_004_DS_read_bit' was not declared in this scope
id_bit = Plugin_004_DS_read_bit();
_P004_Dallas:328: error: 'Plugin_004_DS_write_bit' was not declared in this scope
Plugin_004_DS_write_bit(search_direction);
C:\Users\Admin\Desktop\Easy IoT\ESPEasy\_P004_Dallas.ino: In function 'uint8_t Plugin_004_DS_read()':
_P004_Dallas:380: error: 'Plugin_004_DS_read_bit' was not declared in this scope
if (Plugin_004_DS_read_bit())
C:\Users\Admin\Desktop\Easy IoT\ESPEasy\_P004_Dallas.ino: In function 'void Plugin_004_DS_write(uint8_t)':
_P004_Dallas:394: error: 'Plugin_004_DS_write_bit' was not declared in this scope
Plugin_004_DS_write_bit( (bitMask & ByteToWrite)?1:0);
C:\Users\Admin\Desktop\Easy IoT\ESPEasy\_P005_DHT.ino: In function 'boolean Plugin_005(byte, EventStruct*, String&)':
_P005_DHT:110: error: 'Plugin_005_read_dht_dat' was not declared in this scope
byte data = Plugin_005_read_dht_dat();
C:\Users\Admin\Desktop\Easy IoT\ESPEasy\_P006_BMP085.ino: In function 'boolean Plugin_006(byte, EventStruct*, String&)':
_P006_BMP085:50: error: 'Plugin_006_bmp085_begin' was not declared in this scope
Plugin_006_bmp085_begin();
_P006_BMP085:52: error: 'Plugin_006_bmp085_readTemperature' was not declared in this scope
UserVar[event->BaseVarIndex] = Plugin_006_bmp085_readTemperature();
_P006_BMP085:53: error: 'Plugin_006_bmp085_readPressure' was not declared in this scope
UserVar[event->BaseVarIndex + 1] = ((float)Plugin_006_bmp085_readPressure()) / 100;
C:\Users\Admin\Desktop\Easy IoT\ESPEasy\_P006_BMP085.ino: In function 'boolean Plugin_006_bmp085_begin()':
_P006_BMP085:95: error: 'Plugin_006_bmp085_read8' was not declared in this scope
if (Plugin_006_bmp085_read8(0xD0) != 0x55) return false;
_P006_BMP085:98: error: 'Plugin_006_bmp085_read16' was not declared in this scope
ac1 = Plugin_006_bmp085_read16(BMP085_CAL_AC1);
C:\Users\Admin\Desktop\Easy IoT\ESPEasy\_P006_BMP085.ino: In function 'uint16_t Plugin_006_bmp085_readRawTemperature()':
_P006_BMP085:117: error: 'Plugin_006_bmp085_write8' was not declared in this scope
Plugin_006_bmp085_write8(BMP085_CONTROL, BMP085_READTEMPCMD);
_P006_BMP085:119: error: 'Plugin_006_bmp085_read16' was not declared in this scope
return Plugin_006_bmp085_read16(BMP085_TEMPDATA);
C:\Users\Admin\Desktop\Easy IoT\ESPEasy\_P006_BMP085.ino: In function 'uint32_t Plugin_006_bmp085_readRawPressure()':
_P006_BMP085:128: error: 'Plugin_006_bmp085_write8' was not declared in this scope
Plugin_006_bmp085_write8(BMP085_CONTROL, BMP085_READPRESSURECMD + (oversampling << 6));
_P006_BMP085:132: error: 'Plugin_006_bmp085_read16' was not declared in this scope
raw = Plugin_006_bmp085_read16(BMP085_PRESSUREDATA);
_P006_BMP085:134: error: 'Plugin_006_bmp085_read8' was not declared in this scope
raw |= Plugin_006_bmp085_read8(BMP085_PRESSUREDATA + 2);
C:\Users\Admin\Desktop\Easy IoT\ESPEasy\_P008_RFID.ino: In function 'boolean Plugin_008(byte, EventStruct*, String&)':
_P008_RFID:66: error: 'Plugin_008_interrupt1' was not declared in this scope
attachInterrupt(Settings.TaskDevicePin1[event->TaskIndex], Plugin_008_interrupt1, FALLING);
_P008_RFID:67: error: 'Plugin_008_interrupt2' was not declared in this scope
attachInterrupt(Settings.TaskDevicePin2[event->TaskIndex], Plugin_008_interrupt2, FALLING);
C:\Users\Admin\Desktop\Easy IoT\ESPEasy\_P009_MCP.ino: In function 'boolean Plugin_009(byte, EventStruct*, String&)':
_P009_MCP:46: error: 'Plugin_009_Read' was not declared in this scope
switchstate[event->TaskIndex] = Plugin_009_Read(Settings.TaskDevicePort[event->TaskIndex]);
_P009_MCP:48: error: 'Plugin_009_Config' was not declared in this scope
Plugin_009_Config(Settings.TaskDevicePort[event->TaskIndex], 1);
_P009_MCP:55: error: 'Plugin_009_Read' was not declared in this scope
int state = Plugin_009_Read(Settings.TaskDevicePort[event->TaskIndex]);
_P009_MCP:82: error: 'Plugin_009_Write' was not declared in this scope
Plugin_009_Write(event->Par1, event->Par2);
C:\Users\Admin\Desktop\Easy IoT\ESPEasy\_P013_HCSR04.ino: In function 'boolean Plugin_013(byte, EventStruct*, String&)':
_P013_HCSR04:101: error: 'Plugin_013_interrupt' was not declared in this scope
attachInterrupt(Settings.TaskDevicePin2[event->TaskIndex], Plugin_013_interrupt, CHANGE);
_P013_HCSR04:111: error: 'Plugin_013_read' was not declared in this scope
float value = Plugin_013_read();
_P013_HCSR04:133: error: 'Plugin_013_read' was not declared in this scope
C:\Users\Admin\Desktop\Easy IoT\ESPEasy\_P014_SI7021.ino: In function 'boolean Plugin_014(byte, EventStruct*, String&)':
_P014_SI7021:118: error: 'Plugin_014_si7021_begin' was not declared in this scope
Plugin_014_init = Plugin_014_si7021_begin(res);
_P014_SI7021:122: error: 'Plugin_014_si7021_readValues' was not declared in this scope
if (Plugin_014_init && Plugin_014_si7021_readValues(res) == 0) {
C:\Users\Admin\Desktop\Easy IoT\ESPEasy\_P014_SI7021.ino: In function 'boolean Plugin_014_si7021_begin(uint8_t)':
_P014_SI7021:158: error: 'Plugin_014_si7021_setResolution' was not declared in this scope
ret = Plugin_014_si7021_setResolution(resolution);
C:\Users\Admin\Desktop\Easy IoT\ESPEasy\_P015_TLS2561.ino: In function 'boolean Plugin_015(byte, EventStruct*, String&)':
_P015_TLS2561:157: error: 'Plugin_015_tls2561_begin' was not declared in this scope
Plugin_015_init = Plugin_015_tls2561_begin(integration);
_P015_TLS2561:162: error: 'Plugin_015_tsl2561_calcLux' was not declared in this scope
ret = Plugin_015_tsl2561_calcLux(integration);
C:\Users\Admin\Desktop\Easy IoT\ESPEasy\_P015_TLS2561.ino: In function 'boolean Plugin_015_tls2561_begin(uint8_t)':
_P015_TLS2561:194: error: 'Plugin_015_tsl2561_writeRegister' was not declared in this scope
ret = Plugin_015_tsl2561_writeRegister(TSL2561_CONTROL, TSL2561_POWER_UP);
C:\Users\Admin\Desktop\Easy IoT\ESPEasy\_P017_PN532.ino: In function 'boolean Plugin_017(byte, EventStruct*, String&)':
_P017_PN532:85: error: 'getFirmwareVersion' was not declared in this scope
uint32_t versiondata = getFirmwareVersion();
_P017_PN532:101: error: 'writeCommand' was not declared in this scope
if (writeCommand(Plugin_017_pn532_packetbuffer, 4))
_P017_PN532:107: error: 'readPassiveTargetID' was not declared in this scope
success = readPassiveTargetID(PN532_MIFARE_ISO14443A, uid, &uidLength);
C:\Users\Admin\Desktop\Easy IoT\ESPEasy\_P017_PN532.ino: In function 'uint32_t getFirmwareVersion()':
_P017_PN532:139: error: 'writeCommand' was not declared in this scope
if (writeCommand(Plugin_017_pn532_packetbuffer, 1)) {
_P017_PN532:144: error: 'readResponse' was not declared in this scope
int16_t status = readResponse(Plugin_017_pn532_packetbuffer, sizeof(Plugin_017_pn532_packetbuffer),10);
C:\Users\Admin\Desktop\Easy IoT\ESPEasy\_P017_PN532.ino: In function 'bool readPassiveTargetID(uint8_t, uint8_t*, uint8_t*)':
_P017_PN532:171: error: 'writeCommand' was not declared in this scope
if (writeCommand(Plugin_017_pn532_packetbuffer, 3)) {
_P017_PN532:176: error: 'readResponse' was not declared in this scope
if (readResponse(Plugin_017_pn532_packetbuffer, sizeof(Plugin_017_pn532_packetbuffer), timeout) < 0) {
C:\Users\Admin\Desktop\Easy IoT\ESPEasy\_P017_PN532.ino: In function 'int8_t writeCommand(const uint8_t*, uint8_t)':
_P017_PN532:231: error: 'readAckFrame' was not declared in this scope
return readAckFrame();
C:\Users\Admin\Desktop\Easy IoT\ESPEasy\_P019_PCF8574.ino: In function 'boolean Plugin_019(byte, EventStruct*, String&)':
_P019_PCF8574:46: error: 'Plugin_019_Read' was not declared in this scope
switchstate[event->TaskIndex] = Plugin_019_Read(Settings.TaskDevicePort[event->TaskIndex]);
_P019_PCF8574:53: error: 'Plugin_019_Read' was not declared in this scope
int state = Plugin_019_Read(Settings.TaskDevicePort[event->TaskIndex]);
_P019_PCF8574:80: error: 'Plugin_019_Write' was not declared in this scope
Plugin_019_Write(event->Par1, event->Par2);
C:\Users\Admin\Desktop\Easy IoT\ESPEasy\_P022_PCA9685.ino: In function 'boolean Plugin_022(byte, EventStruct*, String&)':
_P022_PCA9685:56: error: 'Plugin_022_writeRegister' was not declared in this scope
Plugin_022_writeRegister(PCA9685_MODE1, (byte)0x01); // reset the device
_P022_PCA9685:69: error: 'Plugin_022_Write' was not declared in this scope
Plugin_022_Write(event->Par1, event->Par2);
C:\Users\Admin\Desktop\Easy IoT\ESPEasy\_P023_OLED.ino: In function 'boolean Plugin_023(byte, EventStruct*, String&)':
_P023_OLED:92: error: 'Plugin_023_StartUp_OLED' was not declared in this scope
Plugin_023_StartUp_OLED();
_P023_OLED:93: error: 'Plugin_023_clear_display' was not declared in this scope
Plugin_023_clear_display();
_P023_OLED:94: error: 'Plugin_023_sendStrXY' was not declared in this scope
Plugin_023_sendStrXY((char*)"ESP Easy ", 0, 0);
_P023_OLED:166: error: 'Plugin_023_sendStrXY' was not declared in this scope
Plugin_023_sendStrXY(tmp, x, 0);
_P023_OLED:186: error: 'Plugin_023_sendStrXY' was not declared in this scope
Plugin_023_sendStrXY(tmp, event->Par1 - 1, event->Par2 - 1);
C:\Users\Admin\Desktop\Easy IoT\ESPEasy\_P023_OLED.ino: In function 'void Plugin_023_reset_display()':
_P023_OLED:298: error: 'Plugin_023_displayOff' was not declared in this scope
Plugin_023_displayOff();
_P023_OLED:299: error: 'Plugin_023_clear_display' was not declared in this scope
_P023_OLED:300: error: 'Plugin_023_displayOn' was not declared in this scope
Plugin_023_displayOn();
C:\Users\Admin\Desktop\Easy IoT\ESPEasy\_P023_OLED.ino: In function 'void Plugin_023_StartUp_OLED()':
_P023_OLED:306: error: 'Plugin_023_init_OLED' was not declared in this scope
Plugin_023_init_OLED();
_P023_OLED:308: error: 'Plugin_023_displayOff' was not declared in this scope
_P023_OLED:309: error: 'Plugin_023_setXY' was not declared in this scope
Plugin_023_setXY(0, 0);
_P023_OLED:310: error: 'Plugin_023_clear_display' was not declared in this scope
_P023_OLED:311: error: 'Plugin_023_displayOn' was not declared in this scope
C:\Users\Admin\Desktop\Easy IoT\ESPEasy\_P023_OLED.ino: In function 'void Plugin_023_displayOn()':
_P023_OLED:317: error: 'Plugin_023_sendcommand' was not declared in this scope
Plugin_023_sendcommand(0xaf); //display on
C:\Users\Admin\Desktop\Easy IoT\ESPEasy\_P023_OLED.ino: In function 'void Plugin_023_displayOff()':
_P023_OLED:323: error: 'Plugin_023_sendcommand' was not declared in this scope
Plugin_023_sendcommand(0xae); //display off
C:\Users\Admin\Desktop\Easy IoT\ESPEasy\_P023_OLED.ino: In function 'void Plugin_023_clear_display()':
_P023_OLED:332: error: 'Plugin_023_setXY' was not declared in this scope
Plugin_023_setXY(k, 0);
_P023_OLED:336: error: 'Plugin_023_SendChar' was not declared in this scope
Plugin_023_SendChar(0); //clear all COL
C:\Users\Admin\Desktop\Easy IoT\ESPEasy\_P023_OLED.ino: In function 'void Plugin_023_sendCharXY(unsigned char, int, int)':
_P023_OLED:357: error: 'Plugin_023_setXY' was not declared in this scope
Plugin_023_setXY(X, Y);
C:\Users\Admin\Desktop\Easy IoT\ESPEasy\_P090_Event.ino: In function 'boolean Plugin_090(byte, EventStruct*, String&)':
_P090_Event:257: error: 'Plugin_090_Action' was not declared in this scope
Plugin_090_Action(event->TaskIndex, ExtraTaskSettings.TaskDevicePluginConfigLong[0], ExtraTaskSettings.TaskDevicePluginConfigLong[1], ExtraTaskSettings.TaskDevicePluginConfigLong[2]);
_P090_Event:275: error: 'Plugin_090_Action' was not declared in this scope
_P090_Event:292: error: 'Plugin_090_Action' was not declared in this scope
_P090_Event:359: error: 'Plugin_090_Action' was not declared in this scope
_P090_Event:361: error: 'Plugin_090_Action' was not declared in this scope
Plugin_090_Action(event->TaskIndex, ExtraTaskSettings.TaskDevicePluginConfigLong[4], ExtraTaskSettings.TaskDevicePluginConfigLong[5], ExtraTaskSettings.TaskDevicePluginConfigLong[6]);
C:\Users\Admin\Desktop\Easy IoT\ESPEasy\__CPlugin.ino: In function 'void CPluginInit()':
__CPlugin:118: error: 'CPluginCall' was not declared in this scope
CPluginCall(CPLUGIN_PROTOCOL_ADD, 0);
C:\Users\Admin\Desktop\Easy IoT\ESPEasy\__Plugin.ino: In function 'void PluginInit()':
__Plugin:442: error: 'PluginCall' was not declared in this scope
PluginCall(PLUGIN_DEVICE_ADD, 0, dummyString);
exit status 1
Invalid library found in C:\Users\Admin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\1.6.5-1084-ga39ce29\libraries\esp8266: C:\Users\Admin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\1.6.5-1084-ga39ce29\libraries\esp8266
This report would have more information with
"Show verbose output during compilation"
enabled in File > Preferences.
Does anyone have any pointers or can help me out? Thank you in advance.
