Chat freely about anything...
By vSocket
#37638 Hello Guys!
I have a Socket on my vServer programmed in Java an I am flashing the code directly to the ESP.
My ESP connects to the Socket the first time without problems. If I reset the ESP one connection attempt fails before it suceeds. If I power cycle the ESP again it fails two times before it works. And so on...
The errors increase with every connection the ESP establishes.
This problem does not occur if I connect to the socket with my PC or my iPhone
The code is the WifiClient Example but slightly modified. What it does:
1. Connects to WiFi
2. Connects to my TCP Socket on specific port
3. Sends Message to Server
4. Closes Connection
Here is my code:
const char* ssid = "MySSID";
const char* password = "MySecretPassword";
const char* host = "myvserver.com";
  delay(800);
  Serial.println(ssid);
  WiFi.begin(ssid, password);
  Serial.print("Connected with IP ");
  long rssi = WiFi.RSSI();
  Serial.print("Signal strength (RSSI):");
  Serial.print(rssi);
  Serial.println(" dBm");
  WiFiClient client;
  if (!client.connect(host, 36443)) {
    Serial.print("X");
    return;
  Serial.println(host);
  Serial.println("Sending Message to server");
  client.println("Hey I am ESP Boss");
  delay(100);
  String line = client.readStringUntil('\n');
  Serial.print(line);
  client.flush();
  client.stop();
  Serial.println("connection closed");
  Serial.println("Stopping Connection Attemtps");
By vSocket
#41659 Finally I found the Problem.
I did not espect the error to be located in the Java Code that is why I did not post it.
But guess where the Error was located: In the Java Code.
I did not close the connection on the server side :roll:
Code: Select allprivate final Socket socket;
if(reader.read() ==  -1)  // Client disconnected from Server
socket.close();  // THIS is the point
Hope it helps somebody out there :)
