I have a ESP-01 with 1mb flash. How do yo need setup programming? I tried to write flash to ESP more time, but only one start successfully. I can't see anything in serial console. (Arduino IDE 1.6.5)
My Arduino setup is:
Board: Generic ESP8266 Module
Flash Mode: DIO
Flash Frequency: 40mhz
Upload Using: Serial
CPU Frequency: 80 Mhz
Flash Size: 1 Mb (128K SPIFFS)
Reset Method: Ck
Upload Speed: 115200
Port: COM3
The CheckFlashConfig Example is working fine but my code not start. What is wrong? Anybody can help me?
My code is:
/* DHTServer - ESP8266 Webserver with a DHT sensor as an input
Based on ESP8266Webserver, DHTexample, and BlinkWithoutDelay (thank you)
Version 1.0 5/3/2014 Version 1.0 Mike Barela for Adafruit Industries
#include <WiFiClient.h>
#include <ESP8266WebServer.h>
#include <DHT.h>
#define DHTTYPE DHT11
#define DHTPIN 2
const char* ssid = "xxx";
const char* password = "xxx";
IPAddress ip(192,168,0,13); //Node static IP
IPAddress gateway(192,168,0,1);
IPAddress subnet(255,255,255,0);
ESP8266WebServer server(80);
// Initialize DHT sensor
// NOTE: For working with a faster than ATmega328p 16 MHz Arduino chip, like an ESP8266,
// you need to increase the threshold for cycle counts considered a 1 or 0.
// You can do this by passing a 3rd parameter for this threshold. It's a bit
// of fiddling to find the right value, but in general the faster the CPU the
// higher the value. The default for a 16mhz AVR is a value of 6. For an
// Arduino Due that runs at 84mhz a value of 30 works.
// This is for the ESP8266 processor on ESP-01
DHT dht(DHTPIN, DHTTYPE, 11); // 11 works fine for ESP8266
float humidity, temp_f; // Values read from sensor
String webString=""; // String to display
// Generally, you should use "unsigned long" for variables that hold time
unsigned long previousMillis = 0; // will store last temp was read
const long interval = 2000; // interval at which to read sensor
void handle_root() {
server.send(200, "text/plain", "Hello from the weather esp8266, read from /temp or /humidity");
delay(100);
void setup(void)
// You can open the Arduino IDE Serial Monitor window to see what the code is doing
Serial.begin(115200); // Serial connection from ESP-01 via 3.3v console cable
dht.begin(); // initialize temperature sensor
// Connect to WiFi network
WiFi.begin(ssid, password);
WiFi.config(ip, gateway, subnet);
Serial.print("\n\r \n\rWorking to connect");
// Wait for connection
Serial.println("");
Serial.println("DHT Weather Reading Server");
Serial.println(ssid);
Serial.print("IP address: ");
server.on("/", handle_root);
server.on("/temp", [](){ // if you add this subdirectory to your webserver call, you get text below :)
gettemperature(); // read sensor
webString="Temperature: "+String((int)temp_f)+" F"; // Arduino has a hard time with float to string
server.send(200, "text/plain", webString); // send to someones browser when asked
server.on("/humidity", [](){ // if you add this subdirectory to your webserver call, you get text below :)
webString="Humidity: "+String((int)humidity)+"%";
server.begin();
void loop(void)
server.handleClient();
void gettemperature() {
// Wait at least 2 seconds seconds between measurements.
// if the difference between the current time and last time you read
// the sensor is bigger than the interval you set, read the sensor
// Works better than delay for things happening elsewhere also
unsigned long currentMillis = millis();
if(currentMillis - previousMillis >= interval) {
// save the last time you read the sensor
previousMillis = currentMillis;
// Reading temperature for humidity takes about 250 milliseconds!
// Sensor readings may also be up to 2 seconds 'old' (it's a very slow sensor)
humidity = dht.readHumidity(); // Read humidity (percent)
temp_f = dht.readTemperature(true); // Read temperature as Fahrenheit
// Check if any reads failed and exit early (to try again).
if (isnan(humidity) || isnan(temp_f)) {
Serial.println("Failed to read from DHT sensor!");
return;
