Here we can all chat about fixing the AT+ command structure and the associated responses.
By igrr
#3943 Thanks, i'm checking that out.
I've got a bunch of updates pending, including the new TCP/IP api, so this list will need some updating.
Github is blocked in Russia, so i'm having trouble updating the code and following the issues posted there. Will try to sort that out by setting up a vpn tomorrow.
By saper_2
#3964
igrr wrote:Thanks, i'm checking that out.
Take your time :)
igrr wrote:Github is blocked in Russia, so i'm having trouble updating the code and following the issues posted there. Will try to sort that out by setting up a vpn tomorrow.
I'll leave this without comment...
Have you tried using proxy server ?
By dacb
#4301 Any chance we could see a transparent serial to TCP server mode? Right now with the 'official' AT firmware, you can setup a transparent bridge, but only for the client mode. Having a server mode for this would be monumental.
