maker.ifttt.com/trigger/temperatur_for_lav/with/key/d7i62**********hq2DB2i
If I do it manually, then the recipe is working fine and is sending me an alert, so it's not the URL I've messed up
Explore... Chat... Share...
martinayotte wrote:If it is now compiled, at least it is a good step.
I don't know anything about maker.ifttt.com ...
Did you try posting on dummy local server such Apache just to figure out ?
