i see in the datasheet that the pins are all activated by a LOW pulse. In this case , considering that my pulse are HIGH , i need to use a NPN per channel?
thanks
Explore... Chat... Share...
infor_mare wrote:martinayotte wrote:Yes, GPIO15 will be good for those EN pins.
No series resistors, but still GPIO15 pulldown resistor, something like 4K7 or 10K to GND.
So, in your code, digitalWrite(MOTOR_ENABLE, 1) will bring the EN pins to HIGH.[/quoten
Hi mister ..
maybe i need your help . Do you rememmber my solution to enable the l293d with gpio15? On the start the gpio15 is low, so i haven't accidental start of the valve. Than i put high the gpio15 , and it enables the Hbridges.
The Hbridges are two, and they are enabled by the same gpio15. The problem is that if i put high gpio15, they run for only 10 secs ... than i have a sort of blinking for 1 minute, and than the switch off. The esp07 is burning during this job !!!
What does it means? Maybe the esp07 has not enough mA for both? But I have the problem with only one Hbridge too ..... and ... with only a led connected to the gpio15. Where i need to search the problem?
to test my board a put enable l293 on the start connecting them on the v+. Of course i have a switch on of the valve during the boot, but it is to test them! Another problem is the first hBridge. It seems ALWAYS up, it ALWAYS supplies power to the valve. It is drived by the gpio 16,14,12,13 They are free .. no pulldown and pull up on them.
On the other side i have the second hBridge perfectly working. It is drived by gpio : 4, 5, 2,0 (2 pullup, 0 pullup).
Maybe it is the board design?? with the link you can find it (it is ona of my first board, so probably it has some errors).
Thanks for your help in advance!
Mirko
design layout: https://easyeda.com/editor#id=CNkQ82e8qH
