By anecdata
#40432 I'm using my ESP-12s (Adafruit Huzzah and Feather Huzzah versions) on a "Roaming" WiFi network, i.e., same SSID, security, and credentials for multiple Access Points connected to the same (wired) network.
Will the ESP 8266 automatically re-connect to a new AP in a Roaming network if it loses signal from the initial AP, or, do I need to manually reconnect?
Using Arduino IDE 1.6.5, #include <ESP8266WiFi.h>
