I am trying to using an library using avr/interrupt.h, but when I am compling the code, just shows fatal error: avr/interrupt.h: No such file or directory.
Can anyone help with that>
Thanks,
Chichi
Explore... Chat... Share...
fsq0511 wrote:I am trying to using an library using avr/interrupt.hApparently, you are attempting to port some code written for an AVR device to the ESP8266. Depending on what the code does, this may be a simple process, it may be very complex, or it may be impossible. In most cases, it will require you to have a deep understanding of both the original target (the AVR chip) and the new target (the ESP8266) and it would be helpful if you had a lot of experience writing code for embedded devices in C/C++. The fact that you needed to ask the question suggests that you are ill prepared to tackle a task of this level of difficulty.
