Where I buy my ESP8266 boards from... (Banggood)
Explore... Chat... Share...
Moderator: Mmiscool
forlotto wrote:AP name does not appear to change stays stuck at default name ESP.
This becomes a problem when someone has multiple ESP's in their home for instance.
The settings page and the wifi all seem better being less persistent but, there are some issues.
1. AP Name as mentioned
2. Double connection type AP and STA seem to cause the esp to crash.
Resolutions:
- Figure out what is causing ESP SSID to over ride the name I enter LRLIGHT for my SSID
- Have a connect button that will put it in station mode and drop AP until you hit the disconnect button which will bring up AP only mode and take the saved settings out of memory but retain them on the page. While it is nice having both connections the ESP is unable to handle them and handle a simple program without crashing so it is rather pointless to have both modes running... However maybe the ESP32 will fix this with the multicore processor and tons of extra ram.
Just my observations and 2cents.
Believe me I'm not knocking the effort it wasn't fruitless I kinda helped push for dual connection but the truth is if you connect to AP and the settings are remembered by the PC you are connecting from and it is connected on station as well from the same or another device you try to control it it causes the ESP to hang.
This is where people are having troubles I think which is the reason for my suggestion on the fix. The esp in current form is not a have your cake and eat it too device just not enough hardware to handle everything albeit it is and was a valiant effort. Problem is it only works for one or the other not both we just have to live with this plain and simple.
PS the updates were nice!
