- Sun Feb 21, 2016 10:32 pm
#41630
Yes format does indeed work I must have did something wrong the other nite but upon investigation with your advice.
Download Termite for windows:
http://www.compuphase.com/software/termite-3.2.exeInstall termite and be sure it is closed.
Download the latest Basic Flasher from
http://www.esp8266basic.comHit the format flash button then sync like normal press and continue to hold the flash button while holding push the reset button keep holding the flash button until you see a lot of blinking then let it go.
Once flashed hit ok on all of the prompts.
Open up termite select the com that you are on and the correct baud rate.
After 30 seconds passes you hit the reset button on your nodemcu then hit the clear button on termite.
Wait for a response once you see a response in termite you can close termite.
Bring Esp Basic flasher back up and hit the flash firmware.
Once open do the sync again let it flash the firmware.
Once firmware is done flashing press the reset button and wait for about 30 seconds.
Viola everything is clear!
Connect to your ESP wifi connection and visit 192.168.4.1 and get back to business.
NOTE: If you change your wifi settings it is critical to not only reset your ESP but also it helps to reset your router or wifi device depending on if you are connecting station or AP mode the reason being is that your router or your wifi card will keep the setting lingering so it is a must that you do the reset to your router or your wifi depending on how you connect!!!
Never leave blank data in the station mode box you are better off using incorrect data for the SSID and Pass then no data at all keep this in mind.
