I am having some trouble getting the ADC to work and was hoping you could help?
I am trying to build a thermometer using the ADC to read the voltage across the thermistor. The thermistor is around 100k ohms at room temperature so I have used a 400k resistor on the voltage divider to make it within the 0 to 1v range required by the pin.
Reading the PIB using system_ADC_read give a fluctuating value. Also putting a multi meter across the thermistor similarly gives a fluctuating voltage.
I assume it it therefore something to do with my wiring....
I have an ftd1232 supplying a steady 3.35v (measured when not connected to the esp12f). I have connected the power pins to the +/- of the breadboard and then supply the esp and the voltage divider from the breadboard power rails.
In terms of troubleshooting, I have measured the voltage on the breadboard power rails and it too fluctuates both when the voltage divider is connected or not. Also, the same setup using an arduino (here I had the other resistor in the divider as 100k as I didn't need to reduce the voltage) and it works fine.
I suspect I am doing something stupid but can't work it out.. Any help appreciated
Thanks
Lee.
