But the original problem persists. Still no program is left in flash after power is disconnected.
Explore... Chat... Share...
d1414213562 wrote:Thank you on your constant help. Changing to the nodemcu fixes the problem of repeated upload, now this error does not appear anymore.
d1414213562 wrote:Still no program is left in flash after power is disconnected.
martinayotte wrote:d1414213562 wrote:Still no program is left in flash after power is disconnected.
I don't think the Flash is emptied at all. I'm still convince that it is a Boot mode issue where GPIO2/GPIO0 are not HIGH when power is recycled, for some unknown reason.
